Has MKV been tested against Mac OS 10,11 "El Capitan"?
philb1701
Post by philb1701 » Sat Jul 04, 2015 11:00 am
I am considering beginning to test the beta of Mac OS 10.11, but wanted to find out if MKV has been tested against it first?
Re: Has MKV been tested against Mac OS 10,11 "El Capitan"?
Post by Woodstock » Sat Jul 04, 2015 5:21 pm
If you're participating in a beta test, isn't finding out if software you want to use works with it part of the test?
Where's your adventurer spirit? :)
Romansh
Post by Romansh » Sun Jul 05, 2015 5:14 am
Someone else summed it up quite nicely:
Ritsuka wrote:I hope you are not considering installing the beta as your main and only operating system. That will be an epic fail, for every kind of beta.
:P
DrBob
Post by DrBob » Mon Jul 27, 2015 9:26 pm
I have not had any problems with MakeMKV under the Beta for El Captain nor Yosemite. Unlike most Betas, these have not proven to be unusable, to the contrary I have been using them every day without any drama. Are they perfect, no. Are they glitch free, no. Do I think that the average user should be using them, no. But on the other hand, its just not been proven to be the disaster I have encountered working professionally with most all operating systems for the past 35 years.
