John Carter and Prisoners PAL
Up until now I could very reliably convert every Blu Ray into a MKV file. Yesterday I tried and failed multiply times at converting the PAL version of the movies "John Carter" and "Prisoners". I tried copying them with two different computers. I'm using OSX Yosemite and Mavericks, I'm using a Samsung USB Drive (Portable BD Writer SE-506), which is capable of AACS up until v53, I'm using MakeMKV 1.94. Hop I explained my situation sufficiently enough. Thank you in advanced for any help.
Re: John Carter and Prisoners PAL
What would explain the situation better would be the debugging log from your attempts. Please read the FAQ linked in my signature for how to enable debugging, and find the log.
You can post the log as part of a reply, if it is less than 60K in size. Don't bother trying to use the attachment feature - it's broken right now.
Okay, I redownloaded MakeMKV and retried converting them. This time I could successfully convert Prinsoners, even though it's the same version of MakeMKV. John Carter still didn't work, I hope my Log helps.
Debug log started at Thu Jul 2 13:10:15 2015 , written by MakeMKV v1.9.4 darwin(x86-release)
001005:0000 MakeMKV v1.9.4 darwin(x86-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als /Users/johannesbilk/MakeMKV_log.txt
002010:0000 Optisches Laufwerk "BD-RE TSSTcorp BDDVDW SE-506CB TS02d" wurde im Zugriffsmodus des Betriebssystems geöffnet.
003007:0000 Direkter Zugriffsmodus wird verwendet
005050:0000 Evaluierungsversion. Es verbleiben noch 29 von 30 Tagen.
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=mXzSuopu1NU6yRqcE0iHJjN7WxFpStBJUtsw1ACVqVGFaZ+qYiQas3mruXGK25x5gRjnwL4PRLjUAa1rtx1J4WmAb6pkh4akwrLKZvrvgqFR9AtLK+pRSlq+qAZpQs/49ncmbFsnCQRkw2gkdAobCqH2glQwHgZG0g==
DCE=2fDRLbVATHP5eawEOOt6OekUiAm9kJEZaazl2Cg4X6ke0BI5H7uTt+xSX9tjyNDhGb6MLLQMBsaR6BeFwTeaHy7r7UfyMtqYnDCc/ghaVrUimZ//exVTuha4qNYy80VjmbEmgmXKxm5xtkbXwN+wlRZh86SdO1x0ww==
005085:0000 Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
DISCID=21A6427C7F50EB3F4AB3FBEF4A11B9BD81A54B7D
003307:0000 Datei 00251.mpls wurde als Titel 0 hinzugefügt
003307:0000 Datei 00800.mpls wurde als Titel 1 hinzugefügt
003307:0000 Datei 00264.mpls wurde als Titel 2 hinzugefügt
003025:0000 Titel #00545.mpls hat eine Länge von 29 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00547.mpls hat eine Länge von 29 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00548.mpls hat eine Länge von 29 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00000.mpls hat eine Länge von 10 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00020.mpls hat eine Länge von 109 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00070.mpls hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00071.mpls hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00072.mpls hat eine Länge von 13 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00060.mpls hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00061.mpls hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00062.mpls hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00050.mpls hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00051.mpls hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00052.mpls hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003307:0000 Datei 00252.mpls wurde als Titel 3 hinzugefügt
003025:0000 Titel #00053.mpls hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00054.mpls hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00055.mpls hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00073.mpls hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00074.mpls hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00075.mpls hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00063.mpls hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00064.mpls hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00065.mpls hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00011.m2ts hat eine Länge von 24 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00002.m2ts hat eine Länge von 10 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00001.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00003.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00021.m2ts hat eine Länge von 54 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00022.m2ts hat eine Länge von 54 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00504.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00505.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00506.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00004.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00508.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00509.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00510.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00872.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00873.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00874.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00877.m2ts hat eine Länge von 116 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00878.m2ts hat eine Länge von 45 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00879.m2ts hat eine Länge von 111 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00880.m2ts hat eine Länge von 75 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003307:0000 Datei 00881.m2ts wurde als Titel 4 hinzugefügt
003025:0000 Titel #00882.m2ts hat eine Länge von 35 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00883.m2ts hat eine Länge von 58 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00884.m2ts hat eine Länge von 62 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003307:0000 Datei 00885.m2ts wurde als Titel 5 hinzugefügt
003025:0000 Titel #00886.m2ts hat eine Länge von 25 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003307:0000 Datei 00887.m2ts wurde als Titel 6 hinzugefügt
003025:0000 Titel #00888.m2ts hat eine Länge von 54 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00891.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00892.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00893.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00894.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00895.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00896.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00897.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00898.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00899.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00900.m2ts hat eine Länge von 4 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00904.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00906.m2ts hat eine Länge von 63 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003307:0000 Datei 00908.m2ts wurde als Titel 7 hinzugefügt
003025:0000 Titel #00909.m2ts hat eine Länge von 29 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00910.m2ts hat eine Länge von 34 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00911.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00912.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00913.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00915.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00916.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00917.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00918.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00919.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00920.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00921.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00922.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00923.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00924.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00925.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00926.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00928.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00929.m2ts hat eine Länge von 29 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00930.m2ts hat eine Länge von 29 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
005011:0000 Die Aufgabe wurde erfolgreich abgeschlossen
005014:0000 1 Titel werden in Verzeichnis /Users/johannesbilk/Filme/John_Carter gespeichert
001003:0020 DEBUG: Code 1073741829 at ;Z7DF$wp@:v<:$Bc:29393953
001003:0020 DEBUG: Code 100864261 at ep3#"YvFM9:|!chO:29401451
001003:0020 DEBUG: Code 4097 at WRn{wW>gh)%6P.p%:213138770
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00800.m2ts' bei Offset '17791709184'
001003:0020 DEBUG: Code 513 at WRn{wW>gh)%6P.p%:213138770
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00800.m2ts' bei Offset '17795776512'
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00800.m2ts' bei Offset '17796366336'
001003:0020 DEBUG: Code 0 at NO6cEm h"ZpwS!m(f]e):121263038
001003:0020 DEBUG: Code 0 at 0:{7JWIebi~Lc)P*7Hdj:121262302
001003:0020 DEBUG: Code 0 at NO6cEm h"ZpwS!m(f]e):213130559
001003:0020 DEBUG: Code 8689632 at NO6cEm h"ZpwS!m(f]e):29393286
001003:0020 DEBUG: Code 0 at |LP+fTt#xU'BbDIydt"~[:29398967
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Titel 1 in Datei /Users/johannesbilk/Filme/John_Carter/John_Carter_t01.mkv zu speichern schlug fehl
005004:0080 0 Titel wurden gesichert, 1 schlugen fehl
005037:0204 Das Kopieren wurde abgeschlossen. 0 Titel wurden gesichert, 1 schlugen fehl.
Application exited at Thu Jul 2 13:58:16 2015
This error indicates that the drive is having problems reading part of the disk. Usually, cleaning/waxing the disk will fix this, unless there are visible scratches.002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00800.m2ts' bei Offset '17791709184'
Thanks, it worked after I cleaned the Disc, it never looked dirty, but it helped. I guess it's like blowing into the cartridge.
