I have tried a number of times to copy this DVD without success. It seems to read/copy a few titles but misses copying the move (it copies all the behind the scene stuff though). Has anyone had this before?
MakeMKV v1.9.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Karon/MakeMKV_log.txt
Title #1 was added (122 cell(s), 1:35:28)
DEBUG: Code 1099449 at G;#mku >l/C"mrbs$[:29400853
DEBUG: Code 30 at G;#mku >l/C"mrbs$[:213114873
Title #2 was added (170 cell(s), 2:10:42)
Title #3 was added (48 cell(s), 0:35:14)
Title #4 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 was added (1 cell(s), 0:02:20)
Title #42 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #43 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #47 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #49 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #51 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #52 was added (1 cell(s), 0:02:47)
Title #54 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #55 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #57 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #63 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #64 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #65 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #67/1 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #67/2 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #67/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #69 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #71 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 233 at NSwYjHyglQfKsH1qjhxCCUmM:0
Saving 5 titles into directory D:/Video/FINDING_NEMO
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204445696'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204544000'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204871680'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204892160'
DEBUG: Code 0 at k(fa4Qr>30s`i/Ch6|dd:121263038
DEBUG: Code 0 at 8pISX?V5~j -ex(zoL{:121261750
DEBUG: Code 0 at k(fa4Qr>30s`i/Ch6|dd:213130559
DEBUG: Code 100045 at k(fa4Qr>30s`i/Ch6|dd:29393286
DEBUG: Code 0 at w\{@|24x9z9$&`]Geg.Tv:29398967
DEBUG: Code 0 at a`aKZi&T*,]HMe>(1'3:29396414
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:213131893
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:121263406
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:29393907
Failed to save title 0 to file D:/Video/FINDING_NEMO/title00.mkv
DEBUG: Code 30 at j'yVj~><RT>p=>&lZy:213136263
DEBUG: Code 559 at j'yVj~><RT>p=>&lZy:213136286
DEBUG: Code 1560861536 at j'yVj~><RT>p=>&lZy:121268098
DEBUG: Code 610 at j'yVj~><RT>p=>&lZy:213136608
DEBUG: Code 3438837440 at j'yVj~><RT>p=>&lZy:121268420
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '92160'
DEBUG: Code 45 at k(fa4Qr>30s`i/Ch6|dd:29393286
DEBUG: Code 0 at L_TVW$R$msl/cz#LgmU:213132054
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204982272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205201408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205309952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205432832'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205529088'
DEBUG: Code 100356 at k(fa4Qr>30s`i/Ch6|dd:29393286
Failed to save title 1 to file D:/Video/FINDING_NEMO/title01.mkv
3 titles saved, 2 failed
Finding Nemo DVD
Re: Finding Nemo DVD
This is your computer saying that it can't read part of the disk. Next step is cleaning. I'd use Pledge furniture polish to clean/wax it at the same time. Use a soft cotton or microfiber cloth.... No paper towel!Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204871680'
bluepiggy123
Thanks Woodstock but I've tried cleaning it a few times so maybe it's permanently damaged? Could the error be cause by anything else by any chance?
Tapioka
I've had this error only once over the course of many, many years and it was also caused by a damaged DVD. So while I'm no expert at MakeMKV's debug messages I also share the opinion of a disk error.
