Naming a file
boristm
Naming a file
Post by boristm » Sun Jun 21, 2015 4:32 am
When I copy a DVD I always enter the name of the DVD in the title box if it is not already there. However every single time Makemkv insists on naming the file title00.mkv
Is there any way to override this and if not, can this be added to the next release please. It's so infuriating.
Re: Naming a file
Post by Woodstock » Mon Jun 22, 2015 2:13 am
Have you discovered "Expert Mode" yet, which turns on things like manual entry of names and meta data?
Preferences->General->Expert mode. When checked, you will see an extra tab in preferences (Advanced), and you will be able to use profiles to control a lot of things.
boristm
Re: Naming a file
Post by boristm » Mon Jun 22, 2015 8:53 pm
Yeah I've got expert mode on. But I can't see anywhere you can set the title for the exported file
Re: Naming a file
Post by Woodstock » Tue Jun 23, 2015 3:54 am
You don't have this pull-down on yours now?
You can change the generated name:
to whatever you want it to be:
boristm
Re: Naming a file
Post by boristm » Tue Jun 23, 2015 8:55 am
Hi
Yeah I have that pull down. Here's a screenshot of a DVD in it.
http://www.thelastgreatadventure.com/stuff/1.jpg
Here's what happens when I choose it
http://www.thelastgreatadventure.com/stuff/2.jpg
http://www.thelastgreatadventure.com/stuff/3.jpg
And here's Makemkv simply choosing what it wants as the title.
christen
Re: Naming a file
Post by christen » Wed Jul 01, 2015 12:39 am
I was having the same problem. Make sure you select the file on the left, so it is gray. Then you should get more options in the drop down menu. The one you want is called file name.
boristm
Re: Naming a file
Post by boristm » Wed Jul 01, 2015 5:47 pm
Ahhh gotcha...You need to ensure the top most line is selected. Excellent thanks very much.
Now, when you do that MKV forces both underscores in place of spaces, and also puts t00 at the end of the file name. No idea why but is there a way to change that too?
boristm
Re: Naming a file
Post by boristm » Wed Jul 01, 2015 6:06 pm
It's OK I've discovered how to do this :)
