Star Wars IV A New Hope
chrisjohnson00
Post by chrisjohnson00 »
Disk looks pretty flawless, but I can't rip. Here's the debug log (can't attach - getting 'board attachment quota reached'
Debug log started at Thu Jun 25 04:21:43 2015 , written by MakeMKV v1.9.3 darwin(x86-release)
001005:0000 MakeMKV v1.9.3 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/cjohnson/MakeMKV_log.txt
002010:0000 Optical drive "BD-ROM PLDS DVDRWBD DS-6E2SH CD11d" opened in OS access mode.
005075:0000 The new version 1.9.4 is available for download at /download/
DAFD=PAAAADAAAAEABDQkEGgACAQ==
DCE=Ncf1UGDiwo+Y9cJoHAGhIIhlym4BFLIeKgcbxzKh9wOrUOywLkG20NdR80ug+ZJK4J4f2Smu1Fsrba4Hn4YvmfcGSuJvIqhxu273kiRqBcKoVekhPpyqJNN66EGKHjUKpFazsZbw/ZjYAyYOV4yJ+32/IulNnvqupA==
DCE=uJ6RGCsS4kt1hiDxnjuXJr3s0rO/3m1LQeLKHp77QBQH+ZgorIoy+PdOv2rVtd7m3cT8boQlKi5n4cT+GLRDdxSTdxmTo2ZvpSZfrlrPQNPrLhffKm/X+r6jQrshAjxQNvxUoLP+7Vl2SIH18Nq05g38tkIdzBiNyg==
001003:0020 DEBUG: Code 0 at !S_75Gi=1]Zyw"[x:213136723
001003:0020 DEBUG: Code 117572530 at "P?on_+=L:+]k3;i<N:29394298
001003:0020 DEBUG: Code 117572530 at "P?on_+=L:+]k3;i<N:29396575
001003:0020 DEBUG: Code 117572530 at "P?on_+=L:+]k3;i<N:29393930
002003:0000 Error 'Internal error - Input parameter is incorrect (946)' occurred while reading '/AACS/Content001.cer' at offset '0'
001003:0020 DEBUG: Code 0 at OGN_W![3RSr.h4":121261911
001003:0020 DEBUG: Code 0 at OGN_W![3RSr.h4":213129823
001003:0020 DEBUG: Code 1 at OGN_W![3RSr.h4":29395057
005084:0000 Failed to load content hash table, unable to verify integrity of M2TS files.
003317:0000 Loaded 12 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=BF8A9F25C28ADC22A38B5F4CE2B7FA2A537DB9D5
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
tp=PmBOV+Qi2YxYOLTp2bih4frFM8JqNRBdQMK4W3J6pAVq3mwXs98J1W+YPfFrv7VS573/oDtNBsYDzZTgm+AI3tGMb5pUMtF/hfgKSbJeItZDAcl1ly5GM4GjDtVokOb2E+T9qfzgyWzDY4Zfqa/SoDYPd2TKxL7YiFyNZljglRL76JtF32uAcycerxOgZHuS4Tr2pVcc9o147MEzikANF0bZaIuXu7zAmcCyEpDrOrELSM7xfzxR3D/BQzdo=
001003:0020 DEBUG: Code 100 at ]Mh(o}2LDuF:zF,J0Gpg:121265269
001003:0020 DEBUG: Code 0 at fC8N+|?>jrx-z}\c^;&f:121262049
001003:0020 DEBUG: Code 0 at fC8N+|?>jrx-z}\c^;&f:213130168
001003:0020 DEBUG: Code 0 at fC8N+|?>jrx-z}\c^;&f:29393286
001003:0020 DEBUG: Code 0 at %t'c^TBM_c|8vXg7ak#U:213139253
001003:0020 DEBUG: Code 0 at T6"uu#d04-! CXCHaC:121262049
001003:0020 DEBUG: Code 0 at T6"uu#d04-! CXCHaC:121262256
005043:0000 Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
001003:0020 DEBUG: Code 0 at `HF)M4JH[O/5g\_n:213131479
001003:0020 DEBUG: Code 0 at o]#XszW)g'(g(}e:213139046
001003:0020 DEBUG: Code 0 at |otNDj%,yFm.^K^W:29377600
003016:0000 Title #00020.mpls was skipped
003308:0000 File 00850.mpls (angle 1) was added as title #0
003308:0000 File 00850.mpls (angle 2) was added as title #1
003308:0000 File 00850.mpls (angle 3) was added as title #2
003308:0000 File 00850.mpls (angle 4) was added as title #3
003308:0000 File 00850.mpls (angle 5) was added as title #4
003308:0000 File 00850.mpls (angle 6) was added as title #5
003308:0000 File 00850.mpls (angle 7) was added as title #6
003308:0000 File 00850.mpls (angle 8) was added as title #7
003308:0000 File 00850.mpls (angle 9) was added as title #8
003309:0000 Title 00800.mpls is equal to title 00850.mpls and was skipped
003041:0000 Failed to add angle #2 for title #800
003041:0000 Failed to add angle #3 for title #800
003041:0000 Failed to add angle #4 for title #800
003041:0000 Failed to add angle #5 for title #800
003041:0000 Failed to add angle #6 for title #800
003041:0000 Failed to add angle #7 for title #800
003041:0000 Failed to add angle #8 for title #800
003041:0000 Failed to add angle #9 for title #800
003025:0000 Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00300.m2ts was added as title #9
003307:0000 File 00301.m2ts was added as title #10
003025:0000 Title #00198.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/cjohnson/Movies/Star Wars IV A New Hope
001003:0020 DEBUG: Code 1073741829 at ?w{Od(w8M]pFsMke:29393953
001003:0020 DEBUG: Code 100864261 at !S_75Gi=1]Zyw"[x:29401451
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '11307319296'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '11307644928'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '11312627712'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '11317082112'
001003:0020 DEBUG: Code 100860416 at !S_75Gi=1]Zyw"[x:29401451
001003:0020 DEBUG: Code 0 at fC8N+|?>jrx-z}\c^;&f:121263038
001003:0020 DEBUG: Code 0 at ]Mh(o}2LDuF:zF,J0Gpg:121262302
001003:0020 DEBUG: Code 0 at fC8N+|?>jrx-z}\c^;&f:213130559
001003:0020 DEBUG: Code 5525919 at fC8N+|?>jrx-z}\c^;&f:29393286
001003:0020 DEBUG: Code 0 at cv>4h`}>(66qgcH@/'38L:29398967
005003:0000 Failed to save title 10 to file /Users/cjohnson/Movies/Star Wars IV A New Hope/A_New_Hope_t10.mkv
005004:0080 0 titles saved, 1 failed
Re: Star Wars IV A New Hope
There are multiple places where your drive cannot read the disk. MakeMKV can't fix that.... Perhaps cleaning (I would clean and wax with something like Pledge furniture polish) will fix it up and make it readable.
