Blue Ray Hangs
BSW111
Blue Ray Hangs
Post by BSW111 »
Latest version - hangs on MKV encoding of a file based blueray. So my "trial" says it ended 10 days ago, but it will give me a couple days to still try it. Not sure if that has anything to do with it. It IS a good idea to give a few days trial with each new version you put out.
It is the David Gilmore Remember That Night D1. that fails. Goes for about 2 mins and then hangs. There are 3 .00x files in the stream, not sure if that has anything to do with it.
I will be happy to run debug. I really want to buy this from you but it has to work consistently. It looks like you are on the right track to make it so. I want to help.
Barry
I can be reached at b@ezid.com if you want.
Re: Blue Ray Hangs
See the FAQ link in my signature, turn on debug logging, and post the log information in a reply here. Don't bother "attaching" it, just put in the message body, unless it's bigger than about 50K.
