Add library linker command line
jvillain
Post by jvillain » Tue Mar 09, 2010 12:31 am
I get the following and the money line would appear to be
/usr/bin/ld: /tmp/ccOBy7h6.o: undefined reference to symbol 'sem_timedwait@@GLIBC_2.2.5'
/usr/bin/ld: note: 'sem_timedwait@@GLIBC_2.2.5' is defined in DSO /lib64/libpthread.so.0 so try adding it to the linker command line
How do I add /lib64/libpthread.so.0 to the linker line?
I am running Fedora 13. I had successfully built a previous version on Fedora 12.
mkdir -p out
gcc -O3 -D_linux_ -oout/makemkv.full -Imakemkvgui/inc -Ilibmakemkv/inc -Isstring/inc -Ilibdriveio/inc \
        makemkvgui/src/aboutbox.cpp makemkvgui/src/client.cpp makemkvgui/src/dirselectbox.cpp makemkvgui/src/logic.cpp makemkvgui/src/logtext.cpp makemkvgui/src/main.cpp makemkvgui/src/nativefiledialog.cpp makemkvgui/src/mainwnd.cpp makemkvgui/src/marshall.cpp makemkvgui/src/progress.cpp makemkvgui/src/scsiinfo.cpp makemkvgui/src/settingdlg.cpp makemkvgui/src/uisync.cpp makemkvgui/src/viteminfo.cpp makemkvgui/src/backupdlg.cpp makemkvgui/src/str/getstr.cpp makemkvgui/src/str/en_utf16.cpp makemkvgui/src/api_posix.cpp makemkvgui/src/api_linux.cpp makemkvgui/src/logic_posix.cpp tmp/qt_rsrc.cpp tmp/moc_mainwnd.cpp tmp/moc_logtext.cpp tmp/moc_dirselectbox.cpp tmp/moc_aboutbox.cpp tmp/moc_settingdlg.cpp tmp/moc_backupdlg.cpp sstring/src/sstring.cpp libdriveio/src/srlist.cpp \
        -DHAVE_BUILDINFO_H -Itmp \
        -I/usr/include/qt4 -I/usr/lib/qt4/include -L/usr/lib/qt4 -L/usr/lib/qt4/lib -lc -lstdc++ -lQtGui -lQtCore
/lib64/libpthread.so.0: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
make: *** [out/makemkv.full] Error 1
sstlr
Re: Add library linker command line
Post by sstlr » Tue Mar 09, 2010 9:32 am
Try to add "-lpthread" to CFLAGS or CXXFLAGS or LDFLAGS in Makefile, whichever is used for the final gcc linking command (I don't have the Makefile here right now to check myself).
jvillain
Post by jvillain » Tue Mar 09, 2010 5:26 pm
Thanks for your help. Adding -lpthread moved the goal post and -lrt got it to build clean. The full line is below for when the Fedora guys upgrade to 13 and start running into this.
-I/usr/include/qt4 -I/usr/lib/qt4/include -L/usr/lib/qt4 -L/usr/lib/qt4/lib -lc -lstdc++ -lQtGui -lQtCore -lpthread -lrt
Post by mike admin » Wed Mar 10, 2010 9:50 am
Can you please check what happens if you add "-lpthread -lrt" before "-lQtGui -lQtCore", right after "-lc -lstdc++"?
JackieBrown
Post by JackieBrown » Sun Mar 21, 2010 2:03 pm
I get this error when compiling in debian. Where are you putting that line?
edit ** nevermind. jvillain's adjustment fixed it.
