v1.9.4 setup gives the error: directory not empty
electronicsguy
#1 Post by electronicsguy » Fri Jun 19, 2015 5:00 am
I tried to install v.1.9.4 over v 1.9.2, just like I've always done. It asked if I want to remove the existing version and I clicked yes. However, it fails to remove everything in the directory. The file "dtsdecoderdll.dll" still remains even though the uninstallation finishes. But then the installer for 1.9.4 complains that the directory is not empty.
I deleted the file and completed the install. "dtsdecoderdll.dll" is not included anymore in v1.9.4. So is that an oversight or is it not required anymore?
Re: v1.9.4 setup gives the error: directory not empty
#2 Post by Woodstock » Fri Jun 19, 2015 3:11 pm
You are not the only one seeing this - I have to move my personal profiles out of the directory to get the install to work. While that worked with 1.9.3, 1.9.4 kept insisting that the empty directory still wasn't empty, so I renamed it... then it would install.
As for the DTS decoder library... v1.9.3 (where the install problems began) has this note:
DTS-HD decoding is now handled by open-source libdcadec library (dtsdecoderdll.dll is still required for DTS express only)
electronicsguy
#3 Post by electronicsguy » Fri Jun 19, 2015 7:28 pm
thanks for the follow-up. I don't know what DTS express is. Is it a end-user makemkv feature or something used internally?
#4 Post by Woodstock » Fri Jun 19, 2015 11:31 pm
That is something only Mike could answer.... Sorry!
Romansh
#5 Post by Romansh » Sat Jun 20, 2015 1:24 pm
It's an audio format (also known as DTS-HD LBR). As I understand it, it shares very little in common with the other DTS codecs except the name.
michael-m.mueller
#6 Post by michael-m.mueller » Sun Jun 21, 2015 11:49 pm
Before this thread loses its way by talking about something completely different like DTS, could we please return to the annoying fact that 1.9.4 asks for an empty directory???
I ALWAYS used to have my installation files in a sub-directory of my installation path, this is now NOT possible anymore, because 1.9.4 just doesn't want that!
Sorry, but this can only be mistake of a new installation routine, right?
Could you please remove that annoying behaviour in the next version? Like to "This directory isn't empty, do you want to install here anyway?"
Please, that's the only feasable way, isn't it?
Thanks in advance,
Michael
