Feature Request: Please Number all Titles
When ripping titles from Lionsgate Studios in particular, hundreds of title are generated. I know how to select the correct title. But my problem is physically counting through hundreds of titles one by one. It is very easy to miscount. My solution would be to number the titles. e.g.: Check Box Title 01
Re: Feature Request: Please Number all Titles
Are you meaning something put in the left hand selection menu, or elsewhere?
The lower right box should be showing the file name on disk for the title highlighted on the left menu. Those are the names most people are giving out when they answer the "which title is the right one?" questions.
Today I was ripping John Wick. I determined the stream I wanted to rip was 00996.mpls. When I looked in the lower panel MakeMKV reported 00996.mpls was equal to 00820.mpls which was title 211. If in the panel above, where the 1st column is Type and the 2nd column is Description, that is where the Titles should be numbered numerically. I right clicked on the check box to un select all and the counted each check box until I got to 211 starting from checkbox 0. Very tedious and easy to make a mistake. If the Title was labeled 211, I would have been able to navigate to it quickly and accurately.
