Having issues in copying a 50gb BlueRay DVD to my hard disk
georgee
Windows says my BluRay Disc is 47gb and it did copy it b ut only 24gb. I used Woookao in hopes it would decipher it and it did but it broke it into many many chapters. None of the sizes of the segments were not even close to the size of 24gb so to burn it as ONE movie, what do I do?
It would have been OK if there was an option to output ONE MKV file but it made 14 files.
What did I do wrong and how do I correct it?
Re: Having issues in copying a 50gb BlueRay DVD to my hard d
You know, this is a case where seeing your log would take this from "Interesting story" to "may be if you ...."
See the FAQ in my signature for how to turn on debug logging. At least scan the disk you're asking about, and post the log generated here in a message. Don't bother trying to attach it as a file, just past it in as part of the message text.
georgee
I attempted the copy again and it did make, I think, 13 files and here is the LOG:
Debug log started at Sun Jun 14 23:13:53 2015 , written by MakeMKV v1.9.4 win(x64-release)
001005:0000 MakeMKV v1.9.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\patrick/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=2Evs0PIhH7rmR6VZ8AordvPc1bBWhSkBady+Bc+wJp9Gc6j2KeZaR/VXJhGHogqVlZkw/ZLT3l/oif5vt7/3P/dR08AG7XsykX1P2iUHUgzlijTE7ICGl3ug6tN5BxN7q6m1dexkQgwWUN7o5PgcfqrDK+dl9cm3RA==
DCE=vonNpixPMCryUX9p1a9InOJwvzEaaEsiTMN9xCjNRxNCA/qDlNhy/2rYChp06pTU7UxpIn1EtbqAgBfcX/I/8+pPZJqtnyXFxN1lsfhixg2R4kAAwUjcCrKdh0yudSqfzFu3I7+kErbc+64aNPHUaptruWXXKaPFgw==
003317:0000 Loaded 79 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=6B6B83146532B916190A06678C457C8A59E3E653
003307:0000 File 00011.mpls was added as title #0
003307:0000 File 00001.mpls was added as title #1
003025:0000 Title #00888.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.mpls was added as title #2
003307:0000 File 00200.mpls was added as title #3
003025:0000 Title #00000.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00003.m2ts was added as title #4
003307:0000 File 00004.m2ts was added as title #5
003307:0000 File 00005.m2ts was added as title #6
003307:0000 File 00006.m2ts was added as title #7
003307:0000 File 00007.m2ts was added as title #8
003307:0000 File 00008.m2ts was added as title #9
003307:0000 File 00009.m2ts was added as title #10
003025:0000 Title #00011.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00028.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00030.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00042.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00043.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00044.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00045.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00046.m2ts was added as title #11
003307:0000 File 00047.m2ts was added as title #12
003025:0000 Title #00048.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00055.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 13 titles into directory D:/---------------- burning
AV sync issues in D:/---------------- burning/Quantum_of_Solace_t00.mkv
AV sync in 1 at 0:01:00.143 (16.583ms) : encountered overlapping frame, audio skew is +16.583ms
004001:0000 Forced subtitles track #6 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #12 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #14 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #16 turned out to be empty and was removed from output file
AV sync issues in D:/---------------- burning/Quantum_of_Solace_t02.mkv
AV sync in 1 at 0:01:05.106 (13.291ms) : encountered overlapping frame, audio skew is +13.291ms
AV sync issues in D:/---------------- burning/Quantum_of_Solace_t03.mkv
AV sync in 1 at 0:00:37.620 (11.083ms) : encountered overlapping frame, audio skew is +11.083ms
AV sync in 1 at 0:02:24.269 (7.791ms) : encountered overlapping frame, audio skew is +18.875ms
AV sync in 1 at 0:04:04.953 (20.083ms) : encountered overlapping frame, audio skew is +38.958ms
AV sync in 1 at 0:04:04.992 (32ms) : 1 frame(s) dropped to reduce audio skew to +6.958ms
AV sync in 1 at 0:05:21.529 (31.5ms) : encountered overlapping frame, audio skew is +38.458ms
AV sync in 1 at 0:05:21.568 (32ms) : 1 frame(s) dropped to reduce audio skew to +6.458ms
AV sync in 1 at 0:06:58.501 (20.125ms) : encountered overlapping frame, audio skew is +26.583ms
AV sync in 1 at 0:08:17.622 (15.291ms) : encountered overlapping frame, audio skew is +41.875ms
AV sync in 1 at 0:08:17.664 (32ms) : 1 frame(s) dropped to reduce audio skew to +9.875ms
AV sync in 1 at 0:09:35.241 (12.791ms) : encountered overlapping frame, audio skew is +22.666ms
AV sync in 1 at 0:10:57.448 (0.875ms) : encountered overlapping frame, audio skew is +23.541ms
AV sync in 1 at 0:12:18.738 (22.458ms) : encountered overlapping frame, audio skew is +46ms
AV sync in 1 at 0:12:18.784 (32ms) : 1 frame(s) dropped to reduce audio skew to +14ms
AV sync in 1 at 0:13:37.733 (12.416ms) : encountered overlapping frame, audio skew is +26.416ms
AV sync in 1 at 0:14:56.270 (23.208ms) : encountered overlapping frame, audio skew is +49.625ms
AV sync in 1 at 0:14:56.320 (32ms) : 1 frame(s) dropped to reduce audio skew to +17.625ms
AV sync in 1 at 0:16:24.650 (4.041ms) : encountered overlapping frame, audio skew is +21.666ms
AV sync in 1 at 0:17:25.294 (28.083ms) : encountered overlapping frame, audio skew is +49.75ms
AV sync in 1 at 0:17:25.344 (32ms) : 1 frame(s) dropped to reduce audio skew to +17.75ms
AV sync in 1 at 0:18:35.239 (7.125ms) : encountered overlapping frame, audio skew is +24.875ms
AV sync in 1 at 0:19:50.105 (13.541ms) : encountered overlapping frame, audio skew is +38.416ms
AV sync in 1 at 0:19:50.144 (32ms) : 1 frame(s) dropped to reduce audio skew to +6.416ms
AV sync in 1 at 0:21:38.547 (6.333ms) : encountered overlapping frame, audio skew is +12.75ms
AV sync in 1 at 0:23:17.187 (15.791ms) : encountered overlapping frame, audio skew is +28.541ms
AV sync in 1 at 0:24:49.779 (15.5ms) : encountered overlapping frame, audio skew is +44.041ms
AV sync in 1 at 0:24:49.824 (32ms) : 1 frame(s) dropped to reduce audio skew to +12.041ms
AV sync in 1 at 0:26:06.940 (23.583ms) : encountered overlapping frame, audio skew is +35.625ms
AV sync in 1 at 0:26:06.976 (32ms) : 1 frame(s) dropped to reduce audio skew to +3.625ms
AV sync in 1 at 0:27:53.880 (3.833ms) : encountered overlapping frame, audio skew is +7.458ms
AV sync in 1 at 0:29:14.711 (1.25ms) : encountered overlapping frame, audio skew is +8.708ms
AV sync in 1 at 0:30:22.278 (16.5ms) : encountered overlapping frame, audio skew is +25.208ms
AV sync in 1 at 0:31:43.526 (0.166ms) : encountered overlapping frame, audio skew is +25.375ms
AV sync in 1 at 0:32:59.769 (13.166ms) : encountered overlapping frame, audio skew is +38.541ms
AV sync in 1 at 0:32:59.808 (32ms) : 1 frame(s) dropped to reduce audio skew to +6.541ms
AV sync in 1 at 0:34:13.301 (4.208ms) : encountered overlapping frame, audio skew is +10.75ms
AV sync in 1 at 0:35:29.043 (1.666ms) : encountered overlapping frame, audio skew is +12.416ms
AV sync in 1 at 0:36:40.198 (13.583ms) : encountered overlapping frame, audio skew is +26ms
AV sync in 1 at 0:37:52.103 (30.833ms) : encountered overlapping frame, audio skew is +56.833ms
AV sync in 1 at 0:37:52.160 (32ms) : 1 frame(s) dropped to reduce audio skew to +24.833ms
AV sync in 1 at 0:39:10.389 (17.458ms) : encountered overlapping frame, audio skew is +42.291ms
AV sync in 1 at 0:39:10.432 (32ms) : 1 frame(s) dropped to reduce audio skew to +10.291ms
AV sync in 1 at 0:40:18.124 (9.666ms) : encountered overlapping frame, audio skew is +19.958ms
AV sync in 1 at 0:41:49.048 (19.833ms) : encountered overlapping frame, audio skew is +39.791ms
AV sync in 1 at 0:41:49.088 (32ms) : 1 frame(s) dropped to reduce audio skew to +7.791ms
AV sync in 1 at 0:43:21.223 (16.583ms) : encountered overlapping frame, audio skew is +24.375ms
AV sync in 1 at 0:44:47.935 (8.375ms) : encountered overlapping frame, audio skew is +32.75ms
AV sync in 1 at 0:44:47.968 (32ms) : 1 frame(s) dropped to reduce audio skew to +0.75ms
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
005005:0080 13 titles saved
005036:0104 Copy complete. 13 titles saved.
Application exited at Mon Jun 15 00:10:31 2015
24GB would be within the range of sizes for a 106 minute feature, although I'd expect more like 28-30 GB. If it was shot in a format wider than 16:9, the black bars at the top/bottom would account for a significant size reduction.
Are you sure you didn't get the whole moving the first time?
georgee
Windows Explorer says it si 47gb AND YES, IT WAS REDUCED TO the same as other that limit AACS to the 25gb.
THAT and the 12-13 files instead of 47gb AND One file is the issue.
I did get WOOOKAO to work with another program the other day and did RIP and BURN a 48gb to a 50gb disc. But, MakeMKV has never worked for me in producing less than 12-13 files.
I tried the trial of ANYDVD and it will not work as it scans my disc, completes, then you hit copy, it says my A: or B: drive is not available.
OK, you've lost me on this.
If you're intention is to author another BD using the contents of the original, then ripping to MKV is not what you want to do. You should be using the "backup" option, NOT the "open" option. That would do a straight copy of the BD files, with optionally decrypting the data. AACS doesn't enter into the equation, because MakeMKV would remove that.
georgee
Thanks, that makes sense and is what I need to do. I did not understand the difference of COPY and BACKUP. As ONE large file of MKV is fine as my Sony S3100 can handle stacked files of MKV on a 50gb disc and will play them in MKV format instead of the BLU-RAY format and I save lots of space on the disc instead of just ONE disc per movie.
And yet, an even better solution is a network file server, feeding video to network-aware players, and eliminating the optical disks. Many modern BD players can do just that... although they'll respect all the nasty things like Cinavia, that non-BD players ignore. There are several devices on the market that will feed video to a variety of "smart" TVs (my Synology server feeds two Samsung TVs, plus my tablet, several computers, and a couple network media players).
Once the video is ripped from the original disk, all the fragile plastic disks can go into storage.
georgee
Thanks, my Sony S3100 Blu-Ray can sometimes read my file sys on my PC but most of the time, it is looking for "the server" and cant find it and I never knew what "the server" was and Tech Supports dont know either. I am gong to assume it is the one you refer to.
If you have Windows Media Player installed on your PC, it is trying to make some of your content available on the network. I had to stop the service to make it disappear from my network, since the PC doesn't host my content.
You can get an overview of what the service involved is by going to Wikipedia and looking up "DLNA". There are free programs out there that you can run on your PC that will reliably make content available (Windows Media Player doesn't work that well, but Plex has a good reputation), as well as a number of hardware devices that work.
