Kingsman: the Secret Service and Spongebob: Sponge out of Water are refusing to rip. They open up just fine and display their playlists. Then when I go to rip it, it will actually rip a little (Kingsman goes for a minute, Spongebob for 5) and then MakeMKV freezes and becomes unresponsive from this constant error
The source file '/BDMV/STREAM/00500.m2ts' is corrupt or invalid at offset 43247616, attempting to work aroundI have also backed up the discs. Encrypted backup worked fine until I tried to convert it, then unencrypted was zero success. Again both failed with the same errors on all methods.
For reference I did rip Interstellar successfully yesterday.
So I don't know if this is new copy protection or what but I assure you my drive and my PC work fine.
Question:
Is there a fix? Or a better work-around?
