Make MKV Blu-Ray
bnwbass
Make MKV Blu-Ray
#1 Post by bnwbass » Sun Jun 14, 2015 10:15 pm
I am I correct in that Make MKV cannot convert AVCHD files to MKV container? When I open file source no option to select AVCHD Video (.m2ts) files.
thx
bw
Re: Make MKV Blu-Ray
#2 Post by Woodstock » Sun Jun 14, 2015 11:18 pm
Some more detail on what you're trying to do would be in order, before guesses about compatibility with purpose can be made.
Are you trying to open a rip done by another program, or process files from a backup done by MakeMKV?
Debugging logs of what you're trying to do might explain it better.
bnwbass
#3 Post by bnwbass » Mon Jun 15, 2015 3:35 am
I would post log file but I am not to the point of executing the program. I'm just trying to open a BD source file AVCHD Video (.m2ts). Files, then Open file, then select AVCHD Video (.m2ts) but these will not populate in the "select existing source file" So my question is, can makeMKV convert AVCHD Video (.m2ts) to MKV container?
All of my rips are done using AnyDVD HD consisting full structure file format.
thx
bw
#4 Post by Woodstock » Mon Jun 15, 2015 2:58 pm
If you're opening a rip done by another program, you need to open the "index.bdmv" file in the BDMV directory of the BD file system. That will allow you to select the tracks to turn into MKV files.
Or, you could use Handbrake (from handbrake.fr) to process the M2TS files directly, and convert them to MKV or MP4.
bnwbass
#5 Post by bnwbass » Fri Jun 19, 2015 6:13 am
Thanks, this did allow me to convert to MKV container however I am still not seeing 1:1 audio. Result is Lossy not lossless core :MA
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.11 GiB (5%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
