Kingsman And Spongebob: Sponge out of Water ERRORS
railerswim
Post by railerswim »
Issue:
Kingsman: the Secret Service and Spongebob: Sponge out of Water are refusing to rip. They open up just fine and display their playlists. Then when I go to rip it, it will actually rip a little (Kingsman goes for a minute, Spongebob for 5) and then MakeMKV freezes and becomes unresponsive from this constant error
 The source file '/BDMV/STREAM/00500.m2ts' is corrupt or invalid at offset 43247616, attempting to work around
Of course the file/path is different but it occurs multiple times before it halts.
I have also backed up the discs. Encrypted backup worked fine until I tried to convert it, then unencrypted was zero success. Again both failed with the same errors on all methods.
For reference I did rip Interstellar successfully yesterday.
So I don't know if this is new copy protection or what but I assure you my drive and my PC work fine.
Question:
Is there a fix? Or a better work-around?
railerswim
Re: Kingsman And Spongebob: Sponge out of Water ERRORS
So I don't look stupid I realize, duh these are new releases and the bd+ encryption has yet to be cracked.
If it were the BD+, you would normally get a message about "no FUTs generated" (no fix-up tables), and a pointer to a file that can be sent to svq@makemkv.com for analysis.
In this case, something in the data was not as expected, so MakeMKV is trying to work around it. If it succeeds in the work-around, it continues; otherwise, it will have an error later on. If you have debug logging turned on (see the FAQ in my signature), more detail is available as to WHICH work-around(s) are tried.
I would suggest following the instructions in the FAQ to send the logs and files from the BD, so that Mike can have a look at them.
Note that sometimes, a dirty disk is all it takes to get that error; cleaning any fingerprints off before you run the logging pass is always a good idea.
Post by mike admin »
railerswim wrote:Issue:
This is a new feature if 1.9.3 - MakeMKV now always checks M2TS files against the hashes stored on the disc. The "official" explanation is that you have a broken drive - when it reads corrupted data it doesn't report the error but passes corrupted data to the program. This is, unfortunately, quite common.
The other possibility is a bug in MakeMKV.
If you get consistent result when making a backup and MKV file (hashcheck errors both during backup and MKV) then it is certainly a disc/drive issue.
