"The DUFF"
"The DUFF"
Looking for the correct .mpls for "The DUFF" (fiery red colored electronic pick up box version, US)
richhlo1021
Re: "The DUFF"
You should not be so obvious about the source of your disc.
If you were "Sly" enough, your Google foo will lead you to the answer.
Re: "The DUFF"
Funny, thought I was pretty crypticrichhlo1021 wrote:You should not be so obvious about the source of your disc.
Re: "The DUFF"
any luck identifying the correct mpls?WAYFLIX wrote:Looking for the correct .mpls for "The DUFF" (fiery red colored electronic pick up box version, US)
richhlo1021
richhlo1021
Re: "The DUFF"
116, 113, 108, 111, 102, 389, 106, 119, 105, 109, 115, 002, 112, 118, 120, 114, 101, 103, 104, 110, 107 Re: "The DUFF"
Any insight into the possible ..mpls #?richhlo1021 wrote:Code: Select all
Re: "The DUFF"
mpls number can vary, but appears if he's given the correct segment map it's mpls 660 at least on my disc I got mpls 660WAYFLIX wrote:Any insight into the possible ..mpls #?richhlo1021 wrote:Code: Select all
Re: "The DUFF"
Thanks for your help. Same sequence on my 660.mplsdashocker wrote:mpls number can vary, but appears if he's given the correct segment map it's mpls 660 at least on my disc I got mpls 660WAYFLIX wrote:Any insight into the possible ..mpls #?richhlo1021 wrote:Code: Select all
SefirosuVII
Re: "The DUFF"
richhlo1021, Thank You! My log file said something totally different.
