Posix error - Resource temporarily unavailable - The Verdict
ogmiii
Post by ogmiii »
I am using MMKV1.9.3 and had the following result. As an aside I have used MMKV for several years and it has been great. I read a post where it seemed Mike could use more results to refine the process and would be happy to send the necessary files if someone can direct me to the file location on a Max using OS X 10.10.3 and where to send the log? If any one has a cure, I'd love to hear it. As an aside I also tried the same with 1.9.2 same result.
MakeMKV v1.9.3 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ06d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BE12LU38 1.00d" opened in OS access mode.
Backing up disc into folder "/Users/Wade1/Movies/backup/The Verdict"
Loaded 35 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Error 'Posix error - Resource temporarily unavailable' occurred while creating '/Users/Wade1/Movies/backup/The Verdict/BDMV/JAR/01001.jar'
Backup failed
Re: Posix error - Resource temporarily unavailable - The Ver
Does the situation change with v1.9.4?
ogmiii
Post by ogmiii »
After upgrading,it worked.
I did get these messages.
It is an internal Hitachi 5900 RPM drive in a Mac Pro:
MakeMKV v1.9.4 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/Wade1/MakeMKV_log.txt
Downloading latest SVQ(s) to /Users/Wade1/Movies/backup ...
Loaded 40 SVQ file(s)
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
Backup done
