DTS-HD Basic Question
bnwbass
#1 Post by bnwbass » Sat Jun 13, 2015 2:11 pm
Hi all,
In the advanced TAB under dtsdecoderdll.dll location , does it matter the location of the file? I pointed to a old TMT dtsdecoderdll.dll but not working.
Should I move dtsdecoderdll.dll to a system 32 directory? I am simply trying to get a 1:1 file structure conversion to MKV container. Media info shown below is my result and you can see there is no Format profile: MA / Core Lossless Any help please!
Thx
bw
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 49mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.78 GiB (5%)
Title : Surround 5.1
Language : English
Default : Yes
Forced
