"The DUFF"
WAYFLIX
"The DUFF"
#1 Post by WAYFLIX » Fri Jun 12, 2015 12:26 pm
Looking for the correct .mpls for "The DUFF" (fiery red colored electronic pick up box version, US)
richhlo1021
Re: "The DUFF"
#2 Post by richhlo1021 » Sat Jun 13, 2015 5:13 am
You should not be so obvious about the source of your disc.
If you were "Sly" enough, your Google foo will lead you to the answer.
WAYFLIX
Re: "The DUFF"
#3 Post by WAYFLIX » Sat Jun 13, 2015 10:33 am
richhlo1021 wrote:You should not be so obvious about the source of your disc.
Funny, thought I was pretty cryptic :) Sly has never helped me.
dashocker
Re: "The DUFF"
#4 Post by dashocker » Sat Jun 13, 2015 3:16 pm
WAYFLIX wrote:Looking for the correct .mpls for "The DUFF" (fiery red colored electronic pick up box version, US)
any luck identifying the correct mpls?
richhlo1021
Re: "The DUFF"
#5 Post by richhlo1021 » Sat Jun 13, 2015 3:26 pm
richhlo1021
Re: "The DUFF"
#6 Post by richhlo1021 » Sat Jun 13, 2015 7:06 pm
116, 113, 108, 111, 102, 389, 106, 119, 105, 109, 115, 002, 112, 118, 120, 114, 101, 103, 104, 110, 107
WAYFLIX
Re: "The DUFF"
#7 Post by WAYFLIX » Sat Jun 13, 2015 7:41 pm
Any insight into the possible ..mpls #?
dashocker
Re: "The DUFF"
#8 Post by dashocker » Sat Jun 13, 2015 9:56 pm
mpls number can vary, but appears if he's given the correct segment map it's mpls 660 at least on my disc I got mpls 660
WAYFLIX
Re: "The DUFF"
#9 Post by WAYFLIX » Sat Jun 13, 2015 10:07 pm
Thanks for your help. Same sequence on my 660.mpls
SefirosuVII
Re: "The DUFF"
#10 Post by SefirosuVII » Sun Jun 14, 2015 1:36 am
richhlo1021, Thank You! My log file said something totally different.
