makemkvcon, freeze, 100% CPU usage, DESPICABLE_ME_G51
backspace
Post by backspace » Fri Jun 12, 2015 3:19 am
Can someone please help me?
I am having trouble using the Backup feature of MakeMKV with the blu-ray Despicable Me. The backup flies along and then stops suddenly on the file:
/BDMV/BACKUP/BDJO/88888.bdjo
I tried waiting for a few hours, but nothing further happened.
Cancelling from the UI does nothing. Quitting the application issues an in progress warning before quitting.
With the application closed, a process called makemkvcon continues at 100% utilisation. I am then able to kill this process using the terminal.
I am using OS X 10.10.3.
I tried to do the same on a fresh install of OS X 10.6, but the application failed to launch. I tried again on a fresh install of OS X 10.7, but the behaviour was the same as that for OS X 10.10.
Setup Information
MakeMKV version: 1.9.3
Platform: OS X 10.10.3
Disc Protection: AACS v19
OS device name: /dev/rdisk1
Manufacturer: PIONEER
Product: BD-RW BDR-TD03
Revision: 1.00
Serial number: KCDL008117WL
Firmware details: intf=SAT gen=1027 krnl=GENE main=GENE ver=0001
Firmware date: 2010-08-04
Highest AACS version: 19
Disc Information
Label: DESPICABLE_ME_G51
Timestamp: 2010-11-08 20:45:41
Data capacity: 45.98 Gb
Disc type: BD-ROM
Number of layers: 2
MakeMKV_log.txt
Debug log started at Fri Jun 12 02:16:25 2015 , written by MakeMKV v1.9.3 darwin(x86-release)
001005:0000 MakeMKV v1.9.3 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/backspace/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL MATSHITA DVD-R   UJ-867 HA13d" opened in OS access mode.
002010:0000 Optical drive "BD-RE PIONEER BD-RW   BDR-TD03 1.00d" opened in OS access mode.
005072:0000 Backing up disc into folder "/Volumes/Locus/Blu-ray Rips/DESPICABLE_ME_G51"
DAFD=PAAAADAAAAEABDQkEEQEBAQ==
DCE=y6kUalZ0/Fg9NL4XcYm4xTcE9OklkvMDZv5t/JPmRU96bH1AsGaJwfmM6cdCMPYZ2L9v/R+HhLMg6g7JDzhlpeTmh/2eoiEE1++1YUpiqcFQ48N3wItyWgXFJsfmh5Gyk1oQfwxpnlX3KDVocwJZiIdiREqXjB7nAA==
001003:0020 DEBUG: Code 0 at 0Fz':Gj^-j\WC0;c:213139828
001001:0020 DBG ASSERT: Is:U*1Rc^'5YQ,I4w3`P^,!9d36bon"f%!`.1zb_kE-K) at 0Fz':Gj^-j\WC0;c:29403797
Thanks in advance.
backspace
Re: makemkvcon, freeze, 100% CPU usage, DESPICABLE_ME_G51
Post by backspace » Fri Jun 12, 2015 6:47 am
Ugh! I downgraded to v1.9.2 from here: [http://www.makemkv.com/download/old/].
And whilst it hasn't finished the backup yet, 1.9.2 has successfully copied the file /BDMV/BACKUP/BDJO/88888.bdjo, and hasn't yet frozen-up. :D
So it looks like there is something up with version 1.9.3. :?
Post by Woodstock » Fri Jun 12, 2015 2:34 pm
Mike has said there are a few bugs in the code that he has to fix. Until he does, use 1.9.2 unless your drive has had a BD with AACSv54 inserted in it.
backspace
Post by backspace » Fri Jun 12, 2015 10:20 pm
Thank you Woodstock.
Post by mike admin » Sat Jun 13, 2015 3:06 pm
Fixed in 1.9.4
