Backup on version 1.9.3 Hang and uses 100% cpu ubuntu 14.04
goldenfri
#1 Post by goldenfri » Thu Jun 11, 2015 11:16 pm
I am trying to backup a Blu-ray on with version 1.9.3 on Ubuntu 14.04 and I get:
MakeMKV v1.9.3 linux(x64-release) started
Backing up disc into folder "/BLURAY-PATH"
The output file is something like: /BLURAY-PATH/BDMV/BACKUP/BDJO/00006.bdjo
top says the makemkv process is at 100% cpu and it will sit there like that for days. Older versions worked perfect and I have tried the command-line and GUI with the same results.
I also reverted back to version 1.9.1 and its working just fine.
Any ideas?
Re: Backup on version 1.9.3 Hang and uses 100% cpu ubuntu 14
#2 Post by Woodstock » Fri Jun 12, 2015 2:25 am
There have been several bugs reported with 1.9.3, which Mike has acknowledged. I have not seen a schedule for fixing them, though.
As long as you don't encounter a BD with AACS v54, you should be fine with 1.9.2 and earlier. If you do load one, though... You'll be stuck until Mike releases the next version. :roll:
goldenfri
#3 Post by goldenfri » Thu Jun 25, 2015 2:05 am
FYI 1.9.4 seems to have fixed the issue.
