Kingsman: The Seceret Service No FUTs were obtained
kevmitch
Post by kevmitch » Sat Jun 06, 2015 11:38 pm
BD+ code processed but no FUTs were obtained errors may follow
while trying to rip Kingsman: The Seceret Service.
Main title rips, but there are frequent video corruption errors.
Dump emailed to support@makemkv.con
johnmacklin
Re: Kingsman: The Seceret Service No FUTs were obtained
Post by johnmacklin » Sun Jun 07, 2015 10:19 am
What region are you trying to rip?
I've already sent in dumps for the US release and have since successfully ripped the BD.
VikingSven
Post by VikingSven » Mon Jun 08, 2015 6:32 pm
I'm having the same problem, with the UK version. I'll submit the BD+ dump when I can find the instructions on what to do!
Post by Woodstock » Mon Jun 08, 2015 7:02 pm
The dump file name should be in your log window. Sometimes, it can be a link you click on to send it, but often it is too big to do that.
Send the .tgz file to svq@makemkv.com so that Mike can get the information he needs from it.
cas1701
Post by cas1701 » Tue Jun 09, 2015 9:51 am
I've sent Mike the dump. I'm sure he will work his magic soon.
