Unable to open any DVD discs
knappster
Post by knappster »
I have tried 3 so far, Dark Knight, Casino Royale, and The Saint. Every one ends with:
I was hoping to test this on DVD's before deciding if I want to get a BluRay Drive. Here is the full debug code for The Saint:
Error 'Posix error - Bad address' occured while issuing SCSI command to device 'SG:dev_22:0'
DEBUG: Code 0 at ::Zhf|'_Q6oNg~+6vBBA:213130789
DEBUG: Code 0 at ::Zhf|'_Q6oNg~+6vBBA:121263406
Drive DVD+R-DL PIONEER DVD-RW DVR-112D 1.21 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Cell 35 was discarded (structure protection?)
DEBUG: Code 0 at (t{v"#6ZGjx?%@QE&:121263015
Title #0 declared length is 1:55:52 while its real length is 0:00:00 - assuming fake title
Cell 2 was discarded (structure protection?)
Title #1 was added (1 cell(s), 0:02:12)
Title #2 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occured while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
DEBUG: Code 0 at d\JT&#yTI)>,[1c_:121268512
DEBUG: Code 101019395 at {Z$=]lM%.:YjM,H<4U:121263429
DEBUG: Code 101019395 at {Z$=]lM%.:YjM,H<4U:29393654
DEBUG: Code 0 at P[{<2G^ZQ#Q,B]nk@=R:213131939
DEBUG: Code 0 at G73w")`Ep6S|D;C|OR^8:29393516
DEBUG: Code 0 at G73w")`Ep6S|D;C|OR^8:213129639
DEBUG: Code 0 at [)IaemHdrji\Ic;#<f:29403406
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
DEBUG: Code 0 at h7bv5`^|O#:i0Ldx!:29395839
I have 1.5.1 beta for linux x64
I am running: Debian Lenny AMD64
Here is my kernel information: Linux AMD64-bit 2.6.26-2-amd64 #1 SMP Tue Mar 9 22:29:32 UTC 2010 x86_64 GNU/Linux
I can play these DVDs fine on my PC and I am in the correct region, so I'm not quite sure what I'm missing.
If you need any further details, let me know. Thanks for your help.
Re: Unable to open any DVD discs
Post by mike admin »
Please try the latest version, 1.5.2 . It will likely NOT fix the problem, but it will provide additional details abot the error. Please repost the log here. Also, try to add yourself to "cdrom" group.
knappster
Post by knappster »
Interestingly enough it is working in 1.5.1 today. I have rebooted since my post...
And just for documentation sake, my user was already a member of cdrom group.
Would it be possible to stream a dvd / bluray movie from a command line and wrap everything into a script that could be run by MythTV? My ultimate goal is to be able to play bluray discs on a mythtv box by just selecting a play button.
knappster wrote:Would it be possible to stream a dvd / bluray movie from a command line and wrap everything into a script that could be run by MythTV?
Yes. http://www.makemkv.com/developers
