Kingsman: The Seceret Service No FUTs were obtained
kevmitch
Post by kevmitch »
BD+ code processed but no FUTs were obtained errors may follow
while trying to rip Kingsman: The Seceret Service.
Main title rips, but there are frequent video corruption errors.
Dump emailed to support@makemkv.con
johnmacklin
Re: Kingsman: The Seceret Service No FUTs were obtained
Post by johnmacklin »
What region are you trying to rip?
I've already sent in dumps for the US release and have since successfully ripped the BD.
VikingSven
Post by VikingSven »
I'm having the same problem, with the UK version. I'll submit the BD+ dump when I can find the instructions on what to do!
The dump file name should be in your log window. Sometimes, it can be a link you click on to send it, but often it is too big to do that.
Send the .tgz file to svq@makemkv.com so that Mike can get the information he needs from it.
cas1701
Post by cas1701 »
I've sent Mike the dump. I'm sure he will work his magic soon.
