Fatal Error on one machine
lowflow
Re: Fatal Error on one machine
#16 Post by lowflow » Thu Mar 18, 2010 10:59 pm
we all really appreciate your time to fix this issue. I am curious why only a few users seem to be having this issue. :)
setarip_old
#17 Post by setarip_old » Fri Mar 19, 2010 12:00 am
@lowflow
Hi!
Although only two have posted such, I'm guessing that it might have something to do with running 32bit XP SP3...
bobchernow
#18 Post by bobchernow » Fri Mar 19, 2010 12:15 am
I would not want to speculate but it might be 32 bit related but I also saw it on Vista and I think someone saw it on 32bit Win7
Bob
setarip_old
#19 Post by setarip_old » Fri Mar 19, 2010 1:41 am
I'm sure it will be disclosed when it's been remedied...
lowflow
#20 Post by lowflow » Fri Mar 19, 2010 12:30 pm
The issue isn't isolated to x86 flavor only. I tested on Windows 7 x64 as well as x86 and both worked once, then failed the second time I started to use the program. Really strange.
crashman
#21 Post by crashman » Sat Mar 20, 2010 6:22 am
THE ANSWER is that you probably downloaded it on to your desktop in 64bit win 7 or Vista. I've had machines do that. It need a proper setup in my case in
"C:\Program Files (x86)\MakeMKV\makemkv.exe" and make a shortcut from your desktop.
That fixes the problem. Probably used IE which by default throws all downloads on the desktop.
bobchernow
#22 Post by bobchernow » Sat Mar 20, 2010 6:00 pm
Is your ANSWER meant for just the 64 bit or both. I never us IE, downloaded to my downloads dierctory and installed it to c:\program file\makemkv and it fails. I do not understand how you can assume to have the answer to a problem that the developer does not have yet. ?????
Bob (still waiting for the ANSWER). :-)
#23 Post by mike admin » Sun Mar 21, 2010 8:16 am
Please try the latest version - 1.5.2 , it should have this error corrected.
bobchernow
#24 Post by bobchernow » Sun Mar 21, 2010 5:40 pm
I think that is fixed and I may have a different error now. It seems to start every time. I currently do not have a CD drive attached to my Acer Aspire One and when I click on either Open Files, or even Online Help the whole MakeMkv interface disappears. I will probably open this as a different issue. I want to test it with a drive attached first.
Bob
mcmusic
#25 Post by mcmusic » Sun Mar 21, 2010 5:46 pm
This has solved the problem for me totally.
Tested all Ui options and tested rips, all work 100%.
Thanks for great support, a rapid fix and a great product.
FYI - Vista 32bit here.
lowflow
#26 Post by lowflow » Tue Mar 23, 2010 2:17 am
Since the last release 1.5.2, all GUI issues are resolved.
Thanks a million Mike !
Windows 7 x86
