As you (should) know, presently, MakeMKV in FULL disc decrypted BluRay copy mode removes only AACS and BD+ protection. Therefore, you're bound to run into some occasions where such backup copies do not playback properly (More often than not, the playback stops at some point during menu selections).
From what I've seen so far, the primary "culprits" appear to be Universal releases, including "The Fourth Kind" (they appear to use a different menu structure - apparently transferred from their now dormant HD-DVDs)
Therefore, I'd suggest that you create and test the playback of an .ISO image file (created by IMGBurn) before burning an actual disc.
I'd also suggest/request that you be good enough to post about your direct experience regarding such problematic FULL disc BluRay backups to this thread.
Problematic decrypted FULL disc BluRay copies
setarip_old
