I have been running makemkv version 1.9.2 successfully on Ubuntu 14.04. I am trying to upgrade to 1.9.3 but keep getting this error whenever I start MakeMKV:
makemkv[10207]: segfault at 28 ip 00007f25712d61de sp 00007ffcb50427a0 error 4 in libGL.so.1.2[7f2571297000+a1000]
Any suggestions?
MakeMKV 1.9.3 on Ubuntu 14.04 dumps core
Re: MakeMKV 1.9.3 on Ubuntu 14.04 dumps core
Is everything up to date? Also try following the 1st sudo instructions to get some libs added. I am running Ubuntu Gnome 15.04 and 1.9.3 is running fine so far, but this is also my 1st time, didn't upgrade from older version.chasmacd wrote:I have been running makemkv version 1.9.2 successfully on Ubuntu 14.04. I am trying to upgrade to 1.9.3 but keep getting this error whenever I start MakeMKV:
Any suggestions?
I've removed 1.9.2 and then installed 1.9.3. Everything is up to date on my system. I have re-downloaded and re-compiled twice ... no joy
What video card do you have and drivers installed?
I have 2 cards an Intel on-board and an AMD R9 with the Proprietary drivers. Tried removing the AMD drivers and using the stock mesa libGL and still no luck.
Wow, I hope that someone with more Linux knowledge knows how to get around that. Everything I found on Google was always related to video card drivers.... But you already tried that...chasmacd wrote:I have 2 cards an Intel on-board and an AMD R9 with the Proprietary drivers. Tried removing the AMD drivers and using the stock mesa libGL and still no luck.
I'm digging through the Qt libraries now---1.9.2 compiles against qt4 and 1.9.3 compiles against qt5 ... will need to tweak the configure script.
--edit
I took out the qt5 references and re-configured all went well and it installs and runs now
--edit
