Delivery Man Error
boogy886
Delivery Man Error
Post by boogy886 » Tue Jun 02, 2015 7:56 pm
Cannot get Delivery Man blu-ray to convert. I've changed the number of attempts in the IO tab, and still get (what appears to be) read failures. The disk is clean, and plays fine in a blu-ray player. Any ideas?? I think my 18mo old may have cancelled this last run, but there were some of the same errors shown before it was cancelled...
Debug log started at Mon Jun 01 23:18:17 2015 , written by MakeMKV v1.9.1 win(x64-release)
001005:0000 MakeMKV v1.9.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\E6430/MakeMKV_log.txt
005075:0000 The new version 1.9.2 is available for download at /download/
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=KrmIzFSjue61kmkGUiXPA6MzR43p5YX8f/u8oiLCw7EYJBP8fZWiQOJ8EizAqdlgbnE/nklDifdtVX7quW2unVkIOxyal6OHLjRfe18Bk/0PJzTvqqr7LIXmFvxk5svAtygORveUNI3hB2l8hEy5BCBo/mRtmx/2+g==
DCE=ENtLcZ2NUdvO9VSO4MMRIFBKMXKg2b9mv9mqXOkurka2m4rRIMinV/B42M3GDSFI0Fe1GJuMHbTIMJL8fUbxHQeOsG7im3cFWuYTeiaRKOpauN1IJ855gffIBXpb0o2HizrZwbCGcBc93gS/v2gJHP6Gl6M0Ekc5EA==
DISCID=0D4AEB42D56C1E3273C98EB155FEB250876479C3
003025:0000 Title #00603.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00111.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00110.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00130.mpls was added as title #0
003307:0000 File 00100.mpls was added as title #1
003025:0000 Title #00627.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00727.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00703.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00709.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00101.mpls was added as title #2
003307:0000 File 00030.mpls was added as title #3
003025:0000 Title #00020.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00410.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00409.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00302.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00021.m2ts was added as title #4
003025:0000 Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00015.m2ts was added as title #5
003307:0000 File 00014.m2ts was added as title #6
003025:0000 Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00217.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00215.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory Z:/MOVIES
AV sync issues in Z:/MOVIES/Delivery_Man_t01.mkv
AV sync in 1,2 at 0:04:12.335 (5.916ms) : encountered overlapping frame, audio skew is +5.916ms
001003:0020 DEBUG: Code 3221225628 at /@lH%E` NqsJOtl!aS*c=VV)}:121263521
001003:0020 DEBUG: Code 3221225628 at Fc'c!&7>Q@eAw))O:29393953
001003:0020 DEBUG: Code 2 at `|<T"dbf@uC2lNEo:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '26212368384'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '26212694016'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '26213609472'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '26213941248'
001003:0020 DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:121263038
001003:0020 DEBUG: Code 0 at jTMn=P#A1I&}jsuIcdAC:213130168
001003:0020 DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:213130559
001003:0020 DEBUG: Code 12799776 at y6*vfE*%I]?KB[pfW2x&:29393286
001003:0020 DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
005003:0000 Failed to save title 1 to file Z:/MOVIES/Delivery_Man_t01.mkv
005004:0080 0 titles saved, 1 failed
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '26214199296'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '26215710720'
001003:0020 DEBUG: Code 12800640 at y6*vfE*%I]?KB[pfW2x&:29393286
001003:0020 DEBUG: Code 0 at W'$mVX$:bonByR?4^QJ:29396414
RH2=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
001003:0020 DEBUG: Code 0 at 9*{OnY-{rP+!FZT@^K j:29403222
FS ID=<FAILED> C=0
TI=ZeNpjZICAGTscHRgZBh8AABQBAdQ=
001003:0020 DEBUG: Code 0 at 7k]hu60*4|`Ik;U)a:213131893
001003:0020 DEBUG: Code 0 at 7k]hu60*4|`Ik;U)a:121263406
001003:0020 DEBUG: Code 0 at 7k]hu60*4|`Ik;U)a:29393907
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Application exited at Tue Jun 02 01:55:37 2015
Re: Delivery Man Error
Post by Woodstock » Tue Jun 02, 2015 10:06 pm
Messages like this tell the tale:
Your drive cannot read parts of the disk. Cleaning the disk would be a good start. Probably finger prints, possibly minor scratches, given that MOST of the disk seems to be readable.
boogy886
Post by boogy886 » Fri Jun 05, 2015 6:36 pm
Woodstock wrote:Messages like this tell the tale:
I cleaned and cleaned again, before posting, as I thought it was a read error. I exchanged the movie today, we'll see how it goes!
Thanks for your help once again!
