The volume key is unknown - video can't be decrypted
cuban2
Post by cuban2 » Tue May 26, 2015 4:16 am
I am using makemkv 1.9.2 and i still can't decrypted a 2007 blu ray using aacs v3. can anyone help. fyi i am on a 2015 iMac and using a Asus blu ray player.
Re: The volume key is unknown - video can't be decrypted
Post by Woodstock » Tue May 26, 2015 1:42 pm
The debugging information displayed during this process would be helpful... FAQ link in my signature says how to turn it on and find the log.
cuban2
Post by cuban2 » Wed May 27, 2015 2:18 am
Thanks for your reply, i have tried to attach the log file but i get an error message "Sorry, the board attachment quota has been reached." any other way to send you the log file?
Post by Woodstock » Wed May 27, 2015 4:26 am
"Sending" the log file should be via email to svq@makemkv.com so that Mike can have a look at it.
But you can click on the "Code" button above, and paste its contents (if it is less than about 60K) in between the tags that will appear, and we can see if anything obvious stands out.
(the attachment thing has been that way for a year or so. probably something caused by Mike moving to a different hosting provider)
cuban2
Post by cuban2 » Thu May 28, 2015 3:06 am
Debug log started at Wed May 27 02:02:28 2015 , written by MakeMKV v1.9.2 darwin(x86-release)
001005:0000 MakeMKV v1.9.2 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/cuban2/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE ASUS BW-12D1S-U E401d" opened in OS access mode.
005050:0000 Evaluation version, 24 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0818BA6EDEEF651B77CF744272A10DF42CB to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
001003:0020 DEBUG: Code 0 at zL#ez-#.sglg=YjHP:213130766
001003:0020 DEBUG: Code 0 at g)R#mEit:BgH5H>:w!:29395195
001003:0020 DEBUG: Code 0 at g)R#mEit:BgH5H>:w!:121262647
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0CF5614EAFE4325DB24A2CC99826661042A to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
001003:0020 DEBUG: Code 1 at g)R#mEit:BgH5H>:w!:121262647
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0534AE6ABB62E9BCBF4C75A84BA5A9347F3 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
001003:0020 DEBUG: Code 2 at g)R#mEit:BgH5H>:w!:121262647
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0E4ED970C2D007284F7A8A31165AD185E0F to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
001003:0020 DEBUG: Code 3 at g)R#mEit:BgH5H>:w!:121262647
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0C6B79A962BD781AC0F6069A97BD09CB488 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
001003:0020 DEBUG: Code 4 at g)R#mEit:BgH5H>:w!:121262647
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0320B98756E5D3CF8F85185DDC70CA0E8A6 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0D498CEDED1FA7D7517BBD245F92AD5ACB3 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..012ED80FDD8A41CA8A0B59F5BB07F87ECDF to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0A44A886AF12382FC2E53B8B5A095FE5EA4 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..04089B20E1804D98B05CC7308A35E539897 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..062DB0907ECC06132E49012A5DCE2BB2D2C to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..073F7CC9F280026285B40FD45791556DADD to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..09D73D0675CD5A09AE5FAF683C732D291FC to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..00BB9A146C7F4DBC24AC6119E5CA44E1B6D to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..09D251A4A901C4D3B16382A424961061A53 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..046D4CE4D26FBF403397F7FDBD534BEBA2A to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
DEBUG: Code 0 at zL#ez-#.sglg=YjHP:213130306
001003:0020 DEBUG: Code 0 at g)R#mEit:BgH5H>:w!:29396345
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0E6638DDCCDB7A266AFAC586E6496989042 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0242DEBC2B27BFDA44AAAF65930D63FA855 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0C963963D33D9A2655AABD0F320D561D9A2 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0BCD4DAB0B07AEBCF9D9BF0E8B63CFF82FC to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0CEBF9755E174BA48DA4F6345826DCF5247 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0D95C823BCD6ACF33D3816B8D1A05522ACB to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0B7661612E81B5DF4BB3553E130439E704E to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0760B1241061B9E7B43C8FC0FD3481D2226 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..07B82B8D436F128A88B0EEAABF6DB3819A7 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..08694DECF9BAF92382FF718ECB590F1C4C6 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..02E528C87E145DF7F768C9FE5801B9D99D5 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..02A7A9B21F59AA8C1A733C4D1CEC5063942 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0973BD345BF3F7BA3D7C3ACBD0F0B8F268F to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..064737746566D045FC5C4C4CD22B2A86B00 to device 'IoKit:IOBDServices:3bcea778f958b552:ASUS BW-12D1S-U E401'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v31 , MKB saved as /Users/cuban2/Library/MakeMKV/MKB_v31_300.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at s5@l*F~/#rx03KN^:213131801
001003:0020 DEBUG: Code 0 at s5@l*F~/#rx03KN^:213133894
Application exited at Wed May 27 02:24:53 2015
Post by Woodstock » Thu May 28, 2015 6:00 pm
This seems to be the root of the problem:
The operating system reports a hardware problem. Whether it is an actual hardware problem (drive failure) or simply OS X having lost track of the hardware (it happens... OS X isn't immune to "forgetting" hardware), MakeMKV has no way to know. However, the result is that the AACS key isn't being sent to the drive, so it is refusing to deliver the data.
Can you still rip DVDs, or do they give errors as well?
cuban2
Post by cuban2 » Thu May 28, 2015 7:32 pm
Yes Dvd still works only blu rays have issues
Post by Woodstock » Fri May 29, 2015 1:42 am
Interesting - searching for this error message comes up with a lot of unanswered questions over the last 9 years. Closest I saw to a suggestion on how to "fix" it was to unplug the drive from the USB port, then plug it back in. And the person that was told to try that didn't reply as to whether or not it worked. And this forum had a number of hits... but no answers, either.
When you start MakeMKV, what does it report as the highest AACS version seen? We know that v54 will cause drives to stop ripping BDs. Whether or not that would manifest as "HARDWARE ERROR:INTERNAL TARGET FAILURE" is unknown.
cuban2
Post by cuban2 » Fri May 29, 2015 2:51 am
Thank you woodstock for you help. yes I unplugged the Player and powered it down, waited then powered it back up and plunged the usb3 cable back up to the computer. tested all the blu-rays i was having issues with and they all worked. hopefully this helps someone else in the future.
jonandtice
Post by jonandtice » Tue Dec 15, 2015 2:07 am
cuban2 wrote:Thank you woodstock for you help. yes I unplugged the Player and powered it down, waited then powered it back up and plunged the usb3 cable back up to the computer. tested all the blu-rays i was having issues with and they all worked. hopefully this helps someone else in the future.
I had the same issue a few days ago and power cycling the drive was the first thing I tried but it didn't work so I just figured it was the disc I was using. Today I was having the same problem and I found this thread so I tried it again and now everything works again. I think the key is to follow the order described here. Unplug -> Power Off -> Power On -> Plug in. Just mentioning it in case anyone else has the same problem.
