Windows 10 Pro 10122 Fatal Error
richci
#1 Post by richci » Fri May 22, 2015 12:42 pm
My PC just got the latest Windows 10 preview update. Now all disks fail with 'Fatal error occurred, program will now exit'. It happens after clicking the disk, when makeMkv is finding the titles. Windows 10 was working fine with all previous previews.
Is this a known issue? Is there some way I can get logs for investigation?
Rich
Re: Windows 10 Pro 10122 Fatal Error
#2 Post by Woodstock » Fri May 22, 2015 2:14 pm
If you have debug logging enabled, you'll have everything that MakeMKV saw, but... it might not help.
Searching Google for build 10122 of Win10 might net you some information, but I doubt Mike has had any chance to test MakeMKV on it.
richci
#3 Post by richci » Fri May 22, 2015 2:25 pm
Right - unfortunately there is nothing useful in the log.
I couldn't find anything with a web search.
The crash happens when its parsing /AACS/Content000.cer btw.
aquabeef
#4 Post by aquabeef » Sat May 23, 2015 2:00 pm
I am seeing similar behavior. It has locked up at various screens. It was working earlier in the week before the 10122 update for Windows 10. It doesn't always lock at the same place but a frequent log is:
MakeMKV v1.9.2 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09D07459823A75661129206D503ECBB9D42 to device 'SPTI:\Device\CdRom0'
Uploaded the full log here:
https://drive.google.com/file/d/0ByFo8D ... YzZ2M/view
aquabeef
#5 Post by aquabeef » Sat May 23, 2015 2:35 pm
I am also seeing this error. I uploaded a log here:
I think the first error is this:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08B38919C7369AC786E8CA1C01C69DC196B to device 'SPTI:\Device\CdRom0'
I can sometimes get past the scanning phase but it still locks a few minutes into the process of making the mkv.
rjw2558
#6 Post by rjw2558 » Tue May 26, 2015 12:17 am
I just started getting an RPC Protection error on all previously burned discs, also, as of this Windows 10 build. Have resorted to using a Windows 7 laptop with the current MakeMKV version running on it to avoid the issue.
richci
#7 Post by richci » Wed May 27, 2015 12:04 pm
I found that reverting Windows 10 to 10074 (from the Settings->Windows Update->Recovery menu) resolved the issue.
#8 Post by Woodstock » Wed May 27, 2015 2:41 pm
Hopefully, you reported this to Microsoft... Not sure if they hear much from the ripping community during the beta tests...
richci
#9 Post by richci » Wed May 27, 2015 3:03 pm
I did.
aquabeef
#10 Post by aquabeef » Fri May 29, 2015 6:16 pm
How would you phrase the reporting to Microsoft? Is there a specific error or message in the log you would use when reporting it to them?
#11 Post by Woodstock » Fri May 29, 2015 6:36 pm
I'd give them a link to the makemkv download, and describe how it works with build XXXXXX, but build YYYYYY reports this error, using same hardware and software. Short of debugging experience and resources, that's about all you CAN report.
rjw2558
#12 Post by rjw2558 » Sun May 31, 2015 3:18 pm
Isn't it possible this change to Windows 10 was intentional and likely to be permanent (to enforce some sort of DRM thing)? If that's the case, then the MakeMKV software will need to hack around it in a later version, right?
