Last of the Mohicans
dtblair
Post by dtblair »
MakeMKV failed:
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
BD+ dump directory is not set in preferences, BD+ dump not saved
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Re: Last of the Mohicans
Post by setarip_old »
Set a directory for "dumps", so that they can be saved and forwarded for analysis...
dtblair
Post by dtblair »
I have the dump file, it is attached
Post by mike admin »
Should work now.
dtblair
Post by dtblair »
Still failed:
MakeMKV v1.6.0 win(x86-release) started
Downloading latest SVQ(s) to C:/Program Files/MakeMKV/SVQ Directory ...
Loaded 36 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Saved BD+ dump file as C:/Temp/dump_The_Last_of_the_Mohicans_F0D8BFC4ADA4A6BF.tgz
Do you have a file named 00000005.svq in your SVQ directory? If not, please restart MakeMKV and try again. If it fails, download it manually http://www.makemkv.com/svq/00000005.svq
klweds
Post by klweds »
mike admin wrote:Do you have a file named 0000000c in your SVQ directory? If not, please restart MakeMKV and try again. If it fails, download it manually /svq/00000005.svq
This download now fails. Could the SVQ please be re-posted?
If it's from 2010 (date of this message exchange), it is most likely already incorporated into MakeMKV. And, if your have not disabled it, SVQ files are automatically downloaded if they exist for a particular disk.
miss_nancy
Post by miss_nancy »
Last of Mohicans: both makemkv 1.9.10 and 1.10.0 logs showed:
MacOS yosemite. can post text of crash report if you like. main error in progress window, repeated many times:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '595261440'
00800.m2ts was main movie file.
v 1.10.0 crashed 2 out of 3 times, extracting no files.
v 1.9.10 extracted 6 of 9 files, but not 00800.m2ts, and did not crash.
blu-ray player 2.16.5 got two minutes into playing main movie, then froze.
may be bad disk, but no scratches seen on read side.
Do you have details from the OS X crash reporting tool? I'm sure Mike would appreciate the information. Send it to support@makemkv.com for him to see it.
The media read error is the hardware complaining about the disk, but MakeMKV shouldn't be crashing because of that.
miss_nancy
o.k., will send zipped version of textedit file of crash report that macOS generated.
