Hello.
makemkv 1.9.2 new installed. SVQ downloading is enabled.
2d disc no Problem, with FUTs.
3d disc with error, BD+ code processed but no FUTs were obtained, errors may follow.
who can help?
Problem with german exodus 3d
Re: Problem with german exodus 3d
Did you follow the on-screen advice to send the TGZ file generated to svq@makemkv.com so that it can be analyzed?
jamesryan
sent tgz file.
jamesryan
Have you found the Problem?
Dazkine
no reaction as usual;) I also sent 3 tgz files without getting any reaction...
Let AnyDVD decrypt the disk and then use MMKV for making the MKV File..
Mike (who decodes all this stuff, because it's his program) isn't here every day. He's due to show up soon, though.
Dazkine
yeah Woodstock thats correct. But im talking about mails i sent more than months ago. Some kind of short feedback would be nice but instead of that there is nothing...
I have also some Blurays that are makign trouble with MakeMKV. But if there is no feedback when you report bugs and upload tgz files I will just say nothing in future and just use another programm for decoding, for example AnyDVD..
Btw I have successfully ripped the german exodus 3d disk with AnyDVD+MakeMKV.
jamesryan
still the same problem, no FUTs . Mike return?
