Mortdecai DVD problems
mojolobo
Post by mojolobo » Sat May 16, 2015 12:05 pm
An answer in search of a question:
The Mortdecai DVD lists multiple copies of the Film and all but one of them have SERIOUS Audio/Video sync problems.
The Title that actually works-- encodes correctly-- is the one with the "Source title ID" of 23, "File Name" Mortdecai_t05.mkv
You're Welcome!
Re: Mortdecai DVD problems
Post by Woodstock » Sat May 16, 2015 2:36 pm
You need to complete the information - what version of the disk?
On many of the titles that use this form of "copy protection", the "right title" varies with where you buy the disk... A disk from Amazon has a different "correct title" than one from another store.
As for the sync problems, are your referring to the fix-up messages MakeMKV displays during the rip? It is possible they are not a problem... Many "correct" titles will have those same messages, because of the way they're constructed out of multiple segments on the disk.
mstg2000
Post by mstg2000 » Sat May 16, 2015 11:51 pm
This is for the one I bought at Walmart
IMDB lists the running time at 107 minutes (that's 1:47)
Play the movie and you'll see 1:46:42
Mortdecai_t09 is the only one with a time similar.. seemed to work ok.
Source title ID: 23
Duration: 1:46:27
Chapters count: 17
Segment count: 1
Segment map: 2-19
File name: Mortdecai_t09.mkv
