Gone Girl
ozmst3k
Gone Girl
Post by ozmst3k » Fri May 15, 2015 8:24 pm
I'm having a real hard time with this one, the error shows like my drive is not working, but I ran a few test and the drive is working correctly
error- A device which does not exist was specified - occurred while writing data to "I:?Video/Gone_Girl/ Gone_Girl_t01.mkv
Re: Gone Girl
Post by Woodstock » Sat May 16, 2015 2:16 am
More detail needed. Is the drive an external USB, internal SATA, or something in between? Operating sytems is .... ?
ozmst3k
Re: Gone Girl
Post by ozmst3k » Sat May 16, 2015 5:09 am
It is an internal drive SATA, I'm currently using windows 10. I did a lot of movies but only 2 gave me problems.
ozmst3k
Re: Gone Girl
Post by ozmst3k » Sat May 16, 2015 5:11 am
Thank you I will get more information and post it back.
Re: Gone Girl
Post by Woodstock » Sat May 16, 2015 2:32 pm
OK, internal SATA eliminates a whole class of problems that external drives can have.
The report of "drive does not exist" usually means that MakeMKV made the request to write to the drive, and the operating system replied, "What drive?" The fact that MakeMKV made the request means it (drive I:) was there at the start of the process, but something happened to make the operating system disconnect from it after some time.
I would check the system events log for any error messages regarding the drives. If you are logged in as administrator, you can click Start, then Run, then type in:
%windir%\system32\eventvwr.msc /s
The System log is where hardware errors are usually recorded.
