Dolby Atmos
Batiatus
Re: Dolby Atmos
Post by Batiatus » Fri Oct 24, 2014 4:17 am
Sweet, so now we can rip the TrueHD track with Atmos embedded. Now just to wait till the codecs support playback of both.
Question though, is there anything in the metadata that signifies the track is Atmos and not just a regular TrueHD track?
Re: Dolby Atmos
Post by mike admin » Fri Oct 24, 2014 12:31 pm
Batiatus wrote:Question though, is there anything in the metadata that signifies the track is Atmos and not just a regular TrueHD track?
There is one additional substream and one channel extension, but the data format is unknown. For now MakeMKV assumes that is any extension is present, then the extension is Atmos.
Once you open disc in MakeMKV, The codec name on the right pane will show "TrueHD Atmos".
Batiatus
Re: Dolby Atmos
Post by Batiatus » Fri Oct 24, 2014 9:29 pm
Does that get flagged in the metadata of the MKV though so a player can recognize it and designate the Atmos track vs a regular TrueHD track (I'm tlaking about XBMC/KODI specifically). Is there something already in the Metadata or is there something that can be edited with a header editor?
Also, I ripped the disc but the MKV seems to have issues skipping scenes. I'll try ripping again but I've already done it twice. It will skip once or twice and then just keep jumping back to the previous chapter. Annoying little glitch it is.
tatts4Life
Re: Dolby Atmos
Post by tatts4Life » Wed Feb 25, 2015 9:29 pm
When I rip a movie that's supposed to have Dolby Atmos will it give me an option for that form of audio output? When I was ripping Step Up All In for my wife it doesn't give that option. It only gives I believe Dolby trueHD. Yet it says it has Dolby Atmos on the case.
I'm also using the most up to date version of MakeMKV.
nickbuol
Re: Dolby Atmos
Post by nickbuol » Wed Feb 25, 2015 10:43 pm
You will only see the Dolby TrueHD option. I don't believe that there is the ability to rip Atmos tracks yet.
The "Atmos update" that was originally talked about allowed the TrueHD track to be extracted. Before that you could only get DD5.1
So long story short, you are seeing the right options, just no way to rip the Atmos track itself.... yet....
Gimpy
Re: Dolby Atmos
Post by Gimpy » Wed May 13, 2015 7:41 pm
hi, i have a brand new Onkyo Dolby atmos 5.1.2 receiver, the only way i find to play atmos sound from my pc is with the m2ts file from the atmos demo disc, i play it in Kobi (xbmc), audio setting on WASAPI: HDMI, enable passtrough and all dolby and dts option is on.
I have notice the m2ts file load in Koby have 3 audio stream:
1 is Unknown Dolby TrueHD 7.1, i get no sound
2 is Unknown AC3 5.1, i get only a beep sound
3 is Unknown - 5.1 , But here i get the AMAZING Atmos audio sound detect and play loud and clear on my receiver.
I make a little video so you cant see what i say.
https://www.youtube.com/watch?v=ByIe_SLOHV0
I try to play some mkv with atmos track on it, and i get only Dolby ex 6.1., i think Atmos need a spécial audio track to play correctly on my receiver.
boe_d
Re: Dolby Atmos
Post by boe_d » Tue Oct 25, 2016 7:08 pm
I notice with the current version of Makemkv (works great) when I rip a DTS:X movie my oppo 103 streams it to my AV8802 and I get DTS:X on the Marantz display. When I rip a Dolby Atmos disc - e.g. Star Trek Beyond it just says multichannel in streamed through my oppo. Everything is HDMI 2.0 or 2.0a. Could just be my oppo.
