Problem with german exodus 3d
Everything related to Blu-ray 3D and 3D MKV files
jamesryan
#1 Post by jamesryan » Tue May 12, 2015 8:44 pm
Hello.
makemkv 1.9.2 new installed. SVQ downloading is enabled.
2d disc no Problem, with FUTs.
3d disc with error, BD+ code processed but no FUTs were obtained, errors may follow.
who can help?
Re: Problem with german exodus 3d
#2 Post by Woodstock » Wed May 13, 2015 12:46 am
Did you follow the on-screen advice to send the TGZ file generated to svq@makemkv.com so that it can be analyzed?
jamesryan
#3 Post by jamesryan » Wed May 13, 2015 2:54 pm
sent tgz file.
jamesryan
#4 Post by jamesryan » Thu May 21, 2015 8:11 pm
Have you found the Problem?
Dazkine
#5 Post by Dazkine » Thu May 21, 2015 9:42 pm
no reaction as usual;) I also sent 3 tgz files without getting any reaction...
Let AnyDVD decrypt the disk and then use MMKV for making the MKV File..
#6 Post by Woodstock » Fri May 22, 2015 1:03 am
Mike (who decodes all this stuff, because it's his program) isn't here every day. He's due to show up soon, though.
Dazkine
#7 Post by Dazkine » Fri May 22, 2015 11:39 am
yeah Woodstock thats correct. But im talking about mails i sent more than months ago. Some kind of short feedback would be nice but instead of that there is nothing...
I have also some Blurays that are makign trouble with MakeMKV. But if there is no feedback when you report bugs and upload tgz files I will just say nothing in future and just use another programm for decoding, for example AnyDVD..
Btw I have successfully ripped the german exodus 3d disk with AnyDVD+MakeMKV.
jamesryan
#8 Post by jamesryan » Tue Jun 09, 2015 1:04 pm
still the same problem, no FUTs . Mike return?
