Where to find WDTV profile?
JKDenmark
#1 Post by JKDenmark » Thu May 07, 2015 3:32 pm
Under Preferences - Advanced - Options - Default Profile I can only select Default :?: :?: :?:
What am I doing wrong?
Thanks.
JK
Re: Where to find WDTV profile?
#2 Post by Woodstock » Thu May 07, 2015 8:03 pm
Check that the file exists in your program directory. For Windows, that will C:\Program Files (x86)\MakeMKV, and the file name is wdtv.mmcp.xml.
It's contents are:
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name - Default -->
    <name lang="eng">WDTV</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
        setFirstAudioTrackAsDefault="true"
        setFirstSubtitleTrackAsDefault="true"
        setFirstForcedSubtitleTrackAsDefault="true"
        insertFirstChapter00IfMissing="true"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang|single),-sel:(havemulti|havecore),-sel:mvcvideo,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track as is</description>
        <description lang="ger">Track 1:1 kopieren</description>
    </outputSettings>
    <outputSettings name="copyzlib" outputFormat="directCopy">
        <description lang="eng">Copy track as is (zlib compressed)</description>
        <mkvTrackSettings compression="zlib" compressionLevel="9" />
    </outputSettings>
    <outputSettings name="lpcm" outputFormat="LPCM-raw">
        <description lang="eng">Save as raw LPCM</description>
        <description lang="ger">Als RAW LPCM speichern</description>
    </outputSettings>
    <outputSettings name="wavex" outputFormat="LPCM-wavex">
        <description lang="eng">Save as LPCM in WAV container</description>
        <description lang="ger">Als LPCM im WAV-Container speichern</description>
    </outputSettings>
    <outputSettings name="flac-best" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (best compression)</description>
        <description lang="ger">Als FLAC speichern (höchste Komprimierungsstufe)</description>
        <extraArgs>-compression_level 12</extraArgs>
    </outputSettings>
    <outputSettings name="flac-fast" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (fast compression)</description>
        <extraArgs>-compression_level 5</extraArgs>
    </outputSettings>
    <!-- Default rule - copy as is -->
    <trackSettings input="default">
        <output outputSettingsName="copy"
                defaultSelection="$app_DefaultSelectionString">
        </output>
    </trackSettings>
    <!-- Save LPCM mono or stereo as raw LPCM -->
    <trackSettings input="LPCM-stereo">
        <output outputSettingsName="lpcm"
        </output>
    </trackSettings>
    <!-- Put multi-channel LPCM into WAVEX container-->
    <trackSettings input="LPCM-multi">
        <output outputSettingsName="wavex"
        </output>
    </trackSettings>
    <!-- Compress PGS subtitles with ZLIB compression -->
    <trackSettings input="PGS">
        <output outputSettingsName="copyzlib"
        </output>
    </trackSettings>
    <trackSettings input="PGS-forced">
        </output>
    </trackSettings>
</profile>
JKDenmark
#3 Post by JKDenmark » Thu May 07, 2015 8:20 pm
That could probably have been the case. I just updated to 1.9.2 (had 1.9.1) and now it is suddenly there. Why it was not in the previous version is beyond me but it works now.
Thanks.
JK
