IMAX Island of Lemurs Madagascar
JBravo
Post by JBravo »
This bluray does not open with makemkv. It will load and shows it has AACS v50. Makemkv trys to decrypt and open it but is unable to keeps looping back to the "open bluray" screen.
I am using v1.9.2 win x64 which shows my highest AACS of 53.
Debug log started at Fri May 01 12:28:09 2015 , written by MakeMKV v1.9.2 win(x64-release)
001005:0000 MakeMKV v1.9.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\a/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=Bnuh4TGSHxXXfYeF4yCq4J0gNBCHysgtfGZb6+esc5owPDd4g+YKycJ/OkPmPYI0kTAXgabVRcudu5nCZR5eNRNp27h9uhYL9MpIkH9Ga41+f6Hpd/3phAmDByxhhSQ860wA0bnCQjJjrwJd3QjIkDgCfcoKkjanRg==
DCE=cjskwluzzyE6UTrNj16Y6peoILkotYP2HWLZ8PZsZFuXFUlo0QvJEFnLtMqYtxs73VA157S2R/nfaUkIMxWtrL5S97oMUgNYfn7osuv0lO18tYGwTjGeMq+ld1vkhfP36fsP8cc/Y5Ci/YwCLQaP7ZSIjxKiVDAAIA==
DISCID=4389EC81465A3C344FF8C6394B3406C003C25389
003025:0000 Title #00017.mpls has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00100.mpls has length of 2439 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 23 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00118.m2ts has length of 96 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 107 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00120.m2ts has length of 70 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00092.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00093.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 2439 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Application exited at Fri May 01 12:31:03 2015
Re: IMAX Island of Lemurs Madagascar
I'd start with cleaning the disk - even "invisible" fingerprints can disrupt reading a BD, more so than with DVD.
Mike will have to look at the debug information to see if there is something else that stands out.
SpdSurfn
Post by SpdSurfn »
I found that I had my preference minimum file size set to 2700 second, which is 45 minutes. This movie is 40 minutes 39 seconds. As soon as I changed the minimum file size below 2400 seconds, the file opened.
I had originally reset this preference to minimize the unnecessary smaller video files from displaying.
