Star Trek Into Darkness
Goozoo
No audio output on the conversion. All appropriate boxes are checked. This seems to be common to other discs with Dolby True HD and MKV conversion. This was not a problem until I upgraded to version 1.9.2. Any way to install an older version of the software? Any other suggestions welcome.
Re: Star Trek Into Darkness
/download/old/
Did you use a profile that converts the audio to FLAC, or simply copies it raw to the MKV file?
Goozoo
No FLAC conversion. Raw to MKV. FLAC will not play any audio on the OPPO.
