Is MakeMKV having trouble decoding FLAC from MKVs?
ndjamena
#1 Post by ndjamena » Tue Apr 28, 2015 10:14 am
I can't seem to get MakeMKV to decode surround sound FLAC streams from MKV, even ones it wrote itself.
I can convert Stereo fine, but any attempt to decode 5.1 or 7.1 results in debug messages and ultimate failure.
Apparently there's something wrong with my PC, but it's the only one I have so I can't test if that's what's causing this problem.
Can anyone else decode 5.1 FLAC using MakeMKV?
Re: Is MakeMKV having trouble decoding FLAC from MKVs?
#2 Post by Woodstock » Tue Apr 28, 2015 2:24 pm
Which version of MakeMKV are you using?
Versions for Linux require you to have the latest version of ffmpeg installed, if you are dealing with some high-def audio tracks.
ndjamena
#3 Post by ndjamena » Tue Apr 28, 2015 2:36 pm
Windows.
And I'm decoding FLAC tracks (which the current version of MakeMKV made in the first place)... so it's not layout or bitdepth problems.
#4 Post by mike admin » Sat May 02, 2015 8:07 pm
There was a bug like this long time ago (MakeMKV failed to decode flac with huge frames). Please send the log, and preferably a 10-second MKV file cut in mkvmerge.
ndjamena
#5 Post by ndjamena » Sun May 03, 2015 2:23 am
http://www.mediafire.com/watch/8aoa53do ... _Mayer.mkv
It seems to be listing the surround sound FLAC tracks as having a layout of '0', whereas the stereo flac tracks are listed correctly as '2' and the TrueHD tracks are listed as '5.1', '7.1' etc.
This is the Log:
Debug log started at Sun May 03 02:12:30 2015 , written by MakeMKV v1.9.2 win(x64-release)
001005:0000 MakeMKV v1.9.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\User/MakeMKV_log.txt
005015:0000 Saving 1 titles into directory D:/Make using profile 'Copy-&>FLAC' from file 'C:\Program Files (x86)\MakeMKV/CopyFlac.mmcp.xml'
FFENC002: option compression_level=12
FFENC002: option lpc_coeff_precision=15
FFENC002: option lpc_passes=8
FFENC002: option lpc_type=3
FFDEC001: [flac @ 000000002320d7c0] Warning: not compiled with thread support, using thread emulation
001003:0020 DEBUG: Code 6 at {y2BK#O>Xmi@FAscm!'N:121269432
001003:0020 DEBUG: Code 0 at !@N'g=A.pTCA,ua})4AE=:213131640
001003:0020 DEBUG: Code 0 at !@N'g=A.pTCA,ua})4AE=:121265338
001003:0020 DEBUG: Code 0 at %$j{?[Z2s*#e=|QN nx(:213129616
001003:0020 DEBUG: Code 0 at %$j{?[Z2s*#e=|QN nx(:213129869
001003:0020 DEBUG: Code 0 at Apk_t1NIggM[531D63Wmm:29394482
001003:0020 DEBUG: Code 1 at AOu0Cy%:-c`S9FLw)T:29400876
001003:0020 DEBUG: Code 0 at AOu0Cy%:-c`S9FLw)T:213137735
005003:0000 Failed to save title 0 to file D:/Make/Metro_Goldwyn_Mayer_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sun May 03 02:13:19 2015
It happens whether the FLAC was encoded with MakeMKV or 'Other' (ie EAC3To).
ndjamena
#6 Post by ndjamena » Sat May 09, 2015 1:19 am
For that matter there's this too:
        1 file(s) moved.
makemkvcon64 --noscan mkv file:"F:\Make\Input\Work\Toy Story 3 (2010).mkv" 0 "D:
\Make\Output"
DEBUG: Code 32 at lHIe1Nt8USpH[kT`&2MZ+:29393884
Debug logging enabled, log will be saved as C:\Users\Chad/MakeMKV_log_2.txt
DEBUG: Code 0 at r_1-|2N8E.};N\E~:213130444
DEBUG: Code 0 at pV,ZWz/C;|PJty:213130329
Opening files on harddrive at F:\Make\Input\Work\Toy Story 3 (2010).mkv
DEBUG: Code 3 at Y>F+sdf}7ZpH"l^5+ s|Xe>4B:121262049
DEBUG: Code 0 at 9,6rnpxs+Z*q6UUkk:213130260
DEBUG: Code 0 at 8J*|NwZ2DSw)@=:Z1:29394160
Saving 1 titles into directory D:\Make\Output using profile 'Copy-&>FLAC' from f
I get the same debug codes being spat out every single time I remux an MKV (the original files sourced from the same version of MakeMKV).
