mkv from 1.9.2 not filling the screen
Ripman
Post by Ripman » Sat Apr 18, 2015 4:23 pm
I used MakeMKV for an old "flipper" DVD, and the log is below. One side of the DVD is "16x9 FF" and the other is "4x3 FF" -- these are the tokens that are appended to the respective parent directories of the VIDEO_TS folders. I processed the 16x9 side. When I watch the 16x9 side of the disc on a TV or in vlc, it fills the screen. I created an mkv with MakeMKV, and when viewed in vlc, the image has black bars on the sides -- everyone and everything seems thinner.
About 6-7 years ago I processed this disc with DVD Decrypter and DVDFab, and the DVDFab avi I created also filled the screen.
What can I change to make this mkv correct? (Or, what did I set that caused this mkv to display incorrectly?) Many thanks as usual folks.
1.9.2 log.
Debug log started at Sat Apr 18 15:07:58 2015 , written by MakeMKV v1.9.2 win(x86-release)
001005:0000 MakeMKV v1.9.2 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
003028:0000 Title #1 was added (32 cell(s), 2:17:54)
005014:0000 Saving 1 titles into directory C:/75d
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Sat Apr 18 15:51:19 2015
"mediainfo -f" of mkv from MakeMKV.
General
Count                                    : 302
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Unique ID                                : 53431932464355305779578513514227375443
Unique ID                                : 53431932464355305779578513514227375443 (0x28329DA9C8DD6D69BFAC41483E351D53)
Count of video streams                   : 1
Count of audio streams                   : 1
Count of text streams                    : 1
Count of menu streams                    : 1
Video_Format_List                        : MPEG Video
Video_Format_WithHint_List               : MPEG Video
Codecs Video                             : MPEG-2 Video
Video_Language_List                      : English
Audio_Format_List                        : AC-3
Audio_Format_WithHint_List               : AC-3
Audio codecs                             : AC3
Audio_Language_List                      : English
Text_Format_List                         : VobSub
Text_Format_WithHint_List                : VobSub
Text codecs                              : VobSub
Text_Language_List                       : English
Complete name                            : ALL_PRESIDENTS_MEN_16X9FF_t00.mkv
File name                                : ALL_PRESIDENTS_MEN_16X9FF_t00
File extension                           : mkv
Format/Url                               : http://packs.matroska.org/
Format/Extensions usually used           : mkv mk3d mka mks
Commercial name                          : Matroska
Format version                           : Version 2
Codec                                    : Matroska
Codec                                    : Matroska
Codec/Url                                : http://packs.matroska.org/
Codec/Extensions usually used            : mkv mk3d mka mks
File size                                : 4461360874
File size                                : 4.15 GiB
File size                                : 4 GiB
File size                                : 4.2 GiB
File size                                : 4.155 GiB
Duration                                 : 8297789
Duration                                 : 2h 18mn
Duration                                 : 2h 18mn 17s 789ms
Duration                                 : 2h 18mn
Duration                                 : 02:18:17.789
Overall bit rate mode                    : VBR
Overall bit rate                         : 4301253
Overall bit rate                         : 4 301 Kbps
Title                                    : ALL_PRESIDENTS_MEN_16X9FF
Movie name                               : ALL_PRESIDENTS_MEN_16X9FF
Encoded date                             : UTC 2015-04-18 15:11:50
File creation date                       : UTC 2015-04-18 15:11:50.234
File creation date (local)               : 2015-04-18 11:11:50.234
File last modification date              : UTC 2015-04-18 15:30:59.359
File last modification date (local)      : 2015-04-18 11:30:59.359
Writing application                      : MakeMKV v1.9.2 win(x86-release)
Writing library                          : libmakemkv v1.9.2 (1.3.0/1.4.1) win(x86-release)
Video
Count                                    : 299
Kind of stream                           : Video
StreamOrder                              : 0
Unique ID                                : 1
Format                                   : MPEG Video
Commercial name                          : MPEG-2 Video
Format profile                           : Main@Main
Format settings                          : BVOP
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Default
Format settings, GOP                     : M=3, N=12
Internet media type                      : video/MPV
Codec ID                                 : V_MPEG2
Codec ID/Info                            : MPEG 1 or 2 Video
Codec ID/Url                             : http://ffdshow-tryout.sourceforge.net/
Codec                                    : V_MPEG2
Codec                                    : MPEG-2 Video
Codec/Family                             : MPEG-V
Codec/Info                               : MPEG 1 or 2 Video
Codec/Url                                : http://ffdshow-tryout.sourceforge.net/
Codec profile                            : Main@Main
Codec settings, Matrix                   : Default
Bit rate mode                            : VBR
Bit rate                                 : 4023658
Bit rate                                 : 4 024 Kbps
Maximum bit rate                         : 7500000
Maximum bit rate                         : 7 500 Kbps
Width                                    : 720
Width                                    : 720 pixels
Height                                   : 480
Height                                   : 480 pixels
Pixel aspect ratio                       : 0.889
Display aspect ratio                     : 1.333
Display aspect ratio                     : 4:3
Frame rate mode                          : VFR
Frame rate mode                          : Variable
Original frame rate                      : 23.976
Original frame rate                      : 23.976 fps
Standard                                 : NTSC
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Chroma subsampling                       : 4:2:0
Bit depth                                : 8
Bit depth                                : 8 bits
Scan type                                : Progressive
Scan order                               : 2:3 Pulldown
Interlacement                            : PPF
Interlacement                            : Progressive
Delay                                    : 0
Delay                                    : 00:00:00.000
Delay, origin                            : Container
Delay_Original                           : 3598000
Delay_Original                           : 59mn 58s
Delay_Original                           : 59mn 58s 0ms
Delay_Original                           : 00:59:58.000
Delay_Original_Settings                  : drop_frame_flag=0 / closed_gop=1 / broken_link=0
Delay_Original_DropFrame                 : No
Delay_Original_Source                    : Stream
Time code of first frame                 : 00:59:58:00
Time code source                         : Group of pictures header
GOP, Open/Closed                         : Open
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
Buffer size                              : 229376
GOP, Open/Closed of first frame          : Closed
intra_dc_precision                       : 8
Audio
Count                                    : 276
Kind of stream                           : Audio
StreamOrder                              : 1
Unique ID                                : 2
Commercial name                          : AC-3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Codec                                    : AC3
Codec                                    : AC3
Codec/Family                             : AC3
Codec/Info                               : Dolby AC3
Duration                                 : 8297789
Duration                                 : 2h 18mn
Duration                                 : 2h 18mn
Bit rate mode                            : CBR
Bit rate                                 : 192000
Bit rate                                 : 192 Kbps
Channel(s)                               : 1
Channel(s)                               : 1 channel
Channel positions                        : Front: C
Channel positions                        : 1/0/0
ChannelLayout                            : C
Sampling rate                            : 48000
Sampling rate                            : 48.0 KHz
Samples count                            : 398293872
Resolution                               : 16
Resolution                               : 16 bits
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 0
Delay relative to video                  : 0
Delay relative to video                  : 00:00:00.000
Video0 delay                             : 0
Video0 delay                             : 00:00:00.000
Stream size                              : 199146936
Stream size                              : 190 MiB (4%)
Stream size                              : 189.9 MiB
Proportion of this stream                : 0.04464
Title                                    : Mono
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
bsid                                     : 8
dialnorm                                 : -27
dialnorm/String                          : -27 dB
compr                                    : 23.80
compr/String                             : 23.80 dB
dynrng                                   : -18.20
dynrng/String                            : -18.20 dB
acmod                                    : 1
lfeon                                    : 0
dialnorm_Average                         : -27
dialnorm_Average/String                  : -27 dB
dialnorm_Minimum                         : -27
dialnorm_Minimum/String                  : -27 dB
dialnorm_Maximum                         : -27
dialnorm_Maximum/String                  : -27 dB
dialnorm_Count                           : 2
compr_Average                            : 23.80
compr_Average/String                     : 23.80 dB
compr_Minimum                            : 23.80
compr_Minimum/String                     : 23.80 dB
compr_Maximum                            : 23.80
compr_Maximum/String                     : 23.80 dB
compr_Count                              : 2
dynrng_Average                           : -18.20
dynrng_Average/String                    : -18.20 dB
dynrng_Minimum                           : -18.20
dynrng_Minimum/String                    : -18.20 dB
dynrng_Maximum                           : -18.20
dynrng_Maximum/String                    : -18.20 dB
dynrng_Count                             : 2
Text
Count                                    : 210
Kind of stream                           : Text
StreamOrder                              : 2
Unique ID                                : 3
Format                                   : VobSub
Commercial name                          : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Codec                                    : S_VOBSUB
Codec                                    : VobSub
Codec/Info                               : The same subtitle format used on DVDs
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
Menu
Count                                    : 112
Kind of stream                           : Menu
Chapters_Pos_Begin                       : 80
Chapters_Pos_End                         : 112
00:00:00.083                             : en:Chapter 01
00:02:08.695                             : en:Chapter 02
00:06:46.172                             : en:Chapter 03
00:08:04.283                             : en:Chapter 04
00:12:16.535                             : en:Chapter 05
00:18:04.249                             : en:Chapter 06
00:20:02.067                             : en:Chapter 07
00:23:23.702                             : en:Chapter 08
00:30:30.161                             : en:Chapter 09
00:33:27.505                             : en:Chapter 10
00:40:57.321                             : en:Chapter 11
00:46:47.805                             : en:Chapter 12
00:54:15.118                             : en:Chapter 13
00:58:29.873                             : en:Chapter 14
01:00:54.951                             : en:Chapter 15
01:07:55.371                             : en:Chapter 16
01:13:45.087                             : en:Chapter 17
01:21:17.339                             : en:Chapter 18
01:27:28.042                             : en:Chapter 19
01:31:21.909                             : en:Chapter 20
01:32:18.633                             : en:Chapter 21
01:34:01.702                             : en:Chapter 22
01:38:30.571                             : en:Chapter 23
01:43:41.481                             : en:Chapter 24
01:48:56.563                             : en:Chapter 25
01:53:26.833                             : en:Chapter 26
02:00:49.942                             : en:Chapter 27
02:05:26.819                             : en:Chapter 28
02:10:51.944                             : en:Chapter 29
02:13:02.741                             : en:Chapter 30
02:15:05.831                             : en:Chapter 31
02:16:28.246                             : en:Chapter 32
Ripman
Re: mkv from 1.9.2 not filling the screen
Post by Ripman » Sat Apr 18, 2015 5:02 pm
Based on the log in the op, the mkv from 1.9.2 is about 10s short. The movie time is 2.18.09.
I am thinking this may be corrupt timecodes in the source that MakeMKV is having trouble processing. I have posted recently about another older DVD that I have had trouble processing here: http://www.makemkv.com/forum2/viewtopic ... 124#p39124. I think that one is also timecode related.
I'll post back after I try some other things. It may be the case that MakeMKV has trouble with older DVDs (e.g., double-sided, DL).
Ripman
Post by Ripman » Sat Apr 18, 2015 6:10 pm
I just tried processing the DVD with AnyDVD HD. The VIDEO_TS folder plays fine in vlc; the movie fills the screen and shows the correct running time. I created a mkv from that with 1.9.2 and it has the aforementioned two issues: 1. running time doesn't match; and 2. picture doesn't fill the screen.
One interesting note between this problematic DVD (All the President's Men) and the other I have posted about (L'Avventura) is that both get BUP mismatch warnings for VIDEO_TS_1 when compared with their respective VIDEO_TS.ifo. Each DVD has only one title - no extra fluff.
I wonder if some of the older sw just uses the indexes from Video_Ts_1 instead of the main ifo for DVDs with only one title. Weird.
Anyway, I think the problem is predominantly with older DVDs (> 10-15 years), and a bit with MakeMKV. I'll probably try to use pgcedit to get the ifo in a suitable format for MakeMKV to process properly.
PatCarol
Post by PatCarol » Sat Apr 25, 2015 1:56 am
I am also experiencing similar issues with older DVDs (Black Rain, Dances with Wolves for two examples).
I also had a similar problem with a newer, but not a 'latest' DVD (Fantastic 4) for which I was able to create an MKV direct from Disc using Handbrake (see http://www.makemkv.com/forum2/viewtopic.php?f=7&t=9028)
cheers
Pat
Ripman
Post by Ripman » Sat Apr 25, 2015 5:11 pm
Thanks Pat.
For this particular "flipper" DVD, I pulled out the old DVD Decrypter folder, and fed the old folder to HB, which worked out nicely. I used the older folder bc the one I created recently with AnyHD had the same movie duration problems as the mkv from 1.9.2.
There are still 2 older DVDs I have trouble with: 1. L'Avventura; and 2. Seven Days in May. Otherwise, everything works very well.
ndjamena
Post by ndjamena » Sat Apr 25, 2015 8:22 pm
DVD stores it's aspect ratio in two places, one in the inf (menu/playlist ) files and there's another set in the stream headers.
MakeMKV takes the streams from the vobs unaltered, so it doesn't change their headers to match what's in the ifos if there's a contradiction. With the ifos out of the picture there's nothing but the stream headers to indicate the aspect ratio, if they're wrong then the resulting MKV will be wrong too.
It has nothing to do with the age of the DVD, for whatever reason some DVDs were just encoded at the wrong aspect ratio even though the info in the ifos override them with the correct ones.
It's been a problem with MakeMKV forever, but I don't think DVD is a priority.
If you must use MakeMKV for these files, the best fix would be to extract the mpeg2 video tracks using MKVExtract, then run the resulting elementary streams through ReStream or DVD Patcher to correct the aspect ratio in their headers, then remux them into a new file.
http://www.videohelp.com/software/Restream
PatCarol
Post by PatCarol » Sun Apr 26, 2015 7:44 am
No problems Ripman; glad you resolved that one.
Ndjamena - thanks for that feedback - still a bit beyond my abilities at the moment but I will have a good read of that link and see if I can sort it. At the moment using MKV to create a file on disc then running through HB is working for the majority of troublesome DVDs I have.
cheers
Pat
