Hello, relatively new to makemkv but have successfully backed up many blu-rays so far. One is giving me trouble, Makemkv "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
Full message:
MakeMKV v1.9.2 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0328E8FEE5F34782C8CC44738E33E3ED899 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..088F168D3EBD28CC23AD0F8439E80D9CF39 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F16988F11A903A801B2BECD9E06D226E39 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..015C3C58496E9755B1E28745C3E163F0D58 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E2C218B38D33883FCF634F2EEB18493C24 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05EF9B345A4E97031A0ADDDF928DAD4EFE9 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..003FC9DB80E2BC966A1F3EBD3EA8937CBC6 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AF86815959565A0264954AE47BC648E5C0 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..013A8FE954ADB81DAEE8A6BA5A5D62919EF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01825CDBE08AF9AD32231C84530A114210C to device 'SPTI:\Device\CdRom0'
Highest AACS version is v19 , MKB saved as C:\Users\tom/.MakeMKV/MKB_v19_BARRY_LYNDON.tgz
Initially thought disk was corrupted so had it replaced, still the same message. Can anyone help me out and explain why this disk can't be read?
Failed to open disc - Barry Lyndon
Re: Failed to open disc - Barry Lyndon
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'Are the read errors limited to this one title? That is, can you rip other disks?
TSM123456
Other disks are fine, even from the same Stanley Kubrick collection. This is the only one I'm having issues with.
I only have this title on DVD, so I can't say if read errors are common or not.
Ripman
I had no issues working with this particular BD the other week in 1.9.1.
Backup log.
mkv creation log.
Backup log.
Debug log started at Thu Feb 26 18:44:34 2015 , written by MakeMKV v1.9.1 win(x86-release)
001005:0000 MakeMKV v1.9.1 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
005072:0000 Backing up disc into folder "C:/03/BARRY_LYNDON"
DAFD=PAAAADAAAAEABDQkEFgACAQ==
DCE=XRZz89IoxC5RDccXIZGhftuovjaPAwJVgBnBJdEZzFBf7aZIyccwE2DFYIrzJLP9gggnACbj7DKECq+V6OKAc/s5bxyvr2Sr1fnZQHaKgn3q2AzbhpGf2w1pgjITmwArqVyRhOGoM7b/KgDdjy5DSY26lf9pZRDMag==
DCE=fPzKKHQEfgYzkU+P5UkV1WlG7s7288ljg+C7meXWpTR1ZCST4Qvd1VeoINdwnxe6tev4RYsMgC34j466ZoVM4KJ/ChkIwu2tJX7Mb8/klcPiGxAEDl3EpZuvtJbOjIk7RGUAliKsjuP2q3SQrhBsWfBI7cRrKqpKgg==
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Thu Feb 26 19:27:25 2015
Debug log started at Thu Feb 26 19:29:15 2015 , written by MakeMKV v1.9.1 win(x86-release)
003006:0000 Opening files on harddrive at C:/03/BARRY_LYNDON
DISCID=2E1DAD6EB43FDA5956727AE8FA1BAAA288CB30ED
003025:0000 Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00055.mpls was added as title #0
003307:0000 File 00100.mpls was added as title #1
003307:0000 File 00101.mpls was added as title #2
003025:0000 Title #00120.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00001.m2ts was added as title #3
003025:0000 Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00042.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00043.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00044.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00045.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/03
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Thu Feb 26 20:24:52 2015
TSM123456
Tried going to version 1.9.1. Still no luck.
Drive has copied several disks recently (back on V1.9.2), but Barry Lyndon still won't work. Any other thoughts?
Changing MakeMKV versions will not affect whether or not your drive can read the disk. If it has hard errors under 1.9.2, it will have them under 1.9.1 or whatever version you use, until you resolve the hard error.
As shown by Ripman's logs, it isn't an inherent issue with the way the disk is mastered, but it can be a problem with your specific disk, or your drive and that specific disk.
Has the computer been shut down or reset since all of this began? That used to be a silly question even 10 years ago, because no one left a Windows machine running more than a day or two, but... Sometimes, the hardware needs to revert to a known state, and a hard reset (or power down cycle) will do that.
