corrupt file attempting work around errors
bigduc
#1 Post by bigduc » Thu Apr 23, 2015 1:36 am
I'm a newbie to using makemkv. That being said, I downloaded the free trial version and was able to figure out how to use the program, for the most part. However, when the trial period ended, I purchased a registration key so that I could continue using the program. And now, with every Bluray disc I attempt to copy to my hard drive using makemkv, I receive an error that that states that a file is corrupt, attempting a workaround. This will run down the screen dozens of times and then the program will display a message that says that 0 files were saved. Can anyone tell me how to fix this so that I can continue copying my bluray collection to my hard drives? Thanks in advance.
Re: corrupt file attempting work around errors
#2 Post by Woodstock » Thu Apr 23, 2015 1:44 pm
It would be VERY helpful to see the debug logs (see the FAQ in my signature) on this.
The "attempting workaround" is MakeMKV telling you that it encountered something weird in the data, and is applying one of several ways to get around the problem. If it is successful, no problem... If it isn't, it tries something else, until it runs out of alternatives.
What can CAUSE it to need to work around things is usually odd copy-protection schemes, but it is sometimes dirty or damaged disks. The debug logs can provide better insight into this.
cknopp86
#3 Post by cknopp86 » Fri May 29, 2015 1:09 am
I may be able to help because, I think, I'm getting the same message when I try to rip Prisoners. This is what the message looks like when gets done with the makemkv process
he source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18188924928, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18188924928, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18191413248, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18193772544, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18193840128, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18196199424, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18198687744, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18201047040, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18201114624, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18203473920, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18205962240, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18208321536, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18208389120, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18210748416, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18213236736, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18215596032, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18215663616, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18218022912, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18220511232, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18222870528, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18222938112, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18225297408, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18227785728, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18230145024, attempting to work around
The source file '/BDMV/STREAM/00036.m2ts' is corrupt or invalid at offset 18230212608, attempting to work around
This is a small taste of the length that it goes, and the number changes. Any help on this would be greatly appreciated. Thank you.
P.S. I'm super new to makemkv and I'm not real sure if this qualifies as the debug logs or not. Sorry if this isn't helpful.
#4 Post by Woodstock » Fri May 29, 2015 1:50 am
MakeMKV received data that wasn't as expected, and is trying to work around the problem... if it is successful, it moves on; if it isn't, it will report a failure at the end. It can be a very slow process.
Most likely cause is a damaged or dirty disk. It can also be a disk that was not pressed correctly.
Dirt and mild scratches can be dealt with using Pledge furniture polish and a soft cotton or microfiber cloth. Manufacturing defects can only be dealt with by exchanging the disk, hopefully for one not in the same manufacturing batch.
bigduc
#5 Post by bigduc » Fri May 29, 2015 3:45 am
It's not dirty or damaged discs. It's every disc that I try to rip. Including discs that I've previously ripped and brand new discs as well. I've tried cleaning the discs in every known to clean them. The discs are pristine. This only started happening once I paid for the registration key. Any useful help would be much appreciated.
#6 Post by Woodstock » Fri May 29, 2015 4:01 am
"Every disk" points to a drive issue. Can you borrow another drive?
cknopp86
#7 Post by cknopp86 » Fri May 29, 2015 3:17 pm
Woodstock wrote:MakeMKV received data that wasn't as expected, and is trying to work around the problem... if it is successful, it moves on; if it isn't, it will report a failure at the end. It can be a very slow process.
Fixed it! Had some disc cleaner sitting around and gave it a spray and wiped it down with a microfiber cloth. Thanks for the help.
