Using space bar to select
kushari
Post by kushari »
Hi, I've found that you can't use the space bar to select and unselect tracks. I've only got it to work once, and not again. I'm using the latest version 1.9.2 running on Windows 8.1 x64
Re: Using space bar to select
Whether the space bar works or not is a function of where the cursor is. But, you can't always tell where it is, because the highlighting is rather subtle in some Windows color schemes.
If you click on the left side display, that puts the cursor in that box, and space should work for select/deselect. But, by the time you click to allow it to work, you could just as easily click on the selection box itself to toggle it...
If the cursor keys move the highlight on the title, you can use the space bar to select/deselect. If not, it won't work, and you'll have to hit <Tab> until you can, OR click on the window.
