List of DVD/BluRay that haven't worked
duggyhow
Re: List of DVD/BluRay that haven't worked
Post by duggyhow »
I am having problems with the first Rambo movie on bluray, it won't rip. It keeps stopping about a minute into the rip and says it's failed. Does anyone else have this problem or does anyone know what I could do to get it to work? Thanks.
setarip_old
Post by setarip_old »
@duggyhow
Hi!
Try cleaning the disc...
Post by mike admin »
Are there any other messages?
duggyhow
Post by duggyhow »
What up, I get no other messages and I've tried cleaning it. not sure what's wrong. Thanks.
duggyhow wrote:What up, I get no other messages and I've tried cleaning it. not sure what's wrong. Thanks.
Please enable "log debug messages" in preferences, restart the application and see if any DEBUG messages would appear.
2lssfz
Post by 2lssfz »
I upgraded to make mkv version 1.5.1 and tried ripping my Strange Wilderness dvd again, but make mkv still failed to rip it. Looking through the log file I found a couple lines of interest.
003031:0000 Drive DVD+R-DL SONY DVD RW AW-G540A 1.74 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Do I need to flash the firmware on my drive, or is this an issue with make mkv? I ask b/c I am able to rip the movie with a trial version dvdfab in linux using wine without problem.
2lssfz wrote:I upgraded to make mkv version 1.5.1 and tried ripping my Strange Wilderness dvd again, but make mkv still failed to rip it. Looking through the log file I found a couple lines of interest.
I hate to admit it, but there is a small subset of drives where MakeMKV can't bypass drive's hardware mismatching region protection but DVDFab can, they have really great knowledge of undocumented vendor commands. You just happen to have such drive. Please try to find multi-region firmware for your drive, otherwise MakeMKV will not be able to open discs with mismatched region.
kd111
Post by kd111 »
Crossing Over (region 2) won't work. I've visited the link in the log output but I thought also posting here won't hurt and might save others a purchase they can't use (yet? :)
Debug log started at Thu Mar 18 09:42:04 2010 , written by MakeMKV v1.5.1 beta linux(x86-release)
001005:0000 MakeMKV v1.5.1 beta linux(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /home/kd111/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at ,Pg32[l'g7\eA[tsUu9}:213130720
001003:0020 DEBUG: Code 0 at x7?7nxW PVWUivN:121261911
001003:0020 DEBUG: Code 0 at RF4Ti9(Feqmq$yes%xM_:213130122
005050:0000 Evaluation version, 22 day(s) out of 30 remaining
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/[...]
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at /xdaLUT'cSr?7B~_$vf:29395402
001003:0020 DEBUG: Code 0 at /xdaLUT'cSr?7B~_$vf:213133296
setarip_old
@kd111
Hi!
If your source material is either an .ISO image file created by AnyDVD, or something else other than an original, commercial BluRay disc, that's the source of your problem...
kd111
Post by kd111 »
@setarip_old
Thanks, but the source is a genuine commercial region 2 BluRay disc bought from Amazon
Matt_in_Michigan
Post by Matt_in_Michigan »
Tinker Bell DVD is not reading after converting. Please help. Log is below.
Debug log started at Sat Mar 20 12:48:44 2010 , written by MakeMKV v1.5.1 beta win(x86-release)
Using 318720KB for read cache.
001005:0000 MakeMKV v1.5.1 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Matthew/MakeMKV_log.txt
003002:0000 Calculated BUP offset does not match one in IFO header.
003033:0000 Cell 1 was discarded (structure protection?)
001003:0020 DEBUG: Code 0 at |PtOB2PweKz7MQv!Wq:29393976
003035:0000 CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-6 were removed form title start
003038:0000 Cells 36-36 were removed form title end
003028:0000 Title #0 was added (29 cell(s), 1:17:39)
003028:0000 Title #1 was added (29 cell(s), 1:17:39)
003019:0000 Cells 20-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (19 cell(s), 0:12:50)
003019:0000 Cells 13-end were skipped due to cell commands (structure protection?)
003028:0000 Title #3 was added (12 cell(s), 0:10:43)
003025:0000 Title #4 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003028:0000 Title #6 was added (2 cell(s), 0:02:12)
003025:0000 Title #7 has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #8 was added (2 cell(s), 0:02:12)
003028:0000 Title #9 was added (2 cell(s), 0:02:04)
003025:0000 Title #10 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #16 was added (1 cell(s), 0:03:15)
003033:0000 Cell 2 was discarded (structure protection?)
003028:0000 Title #17 was added (1 cell(s), 0:03:55)
003028:0000 Title #18 was added (1 cell(s), 0:03:55)
003028:0000 Title #19 was added (1 cell(s), 0:03:55)
003033:0000 Cell 3 was discarded (structure protection?)
003019:0000 Cells 4-end were skipped due to cell commands (structure protection?)
003028:0000 Title #20 was added (2 cell(s), 0:04:00)
003028:0000 Title #21 was added (2 cell(s), 0:04:00)
003028:0000 Title #22 was added (2 cell(s), 0:04:00)
003028:0000 Title #23 was added (1 cell(s), 0:10:06)
003028:0000 Title #24 was added (1 cell(s), 0:10:06)
003028:0000 Title #25 was added (1 cell(s), 0:10:06)
003028:0000 Title #26 was added (1 cell(s), 0:10:06)
003028:0000 Title #27 was added (1 cell(s), 0:10:06)
003028:0000 Title #28 was added (1 cell(s), 0:10:06)
003028:0000 Title #29 was added (1 cell(s), 0:02:34)
003025:0000 Title #30 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #31 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 5-end were skipped due to cell commands (structure protection?)
003028:0000 Title #32 was added (4 cell(s), 0:05:24)
003028:0000 Title #33 was added (4 cell(s), 0:05:24)
003028:0000 Title #34 was added (2 cell(s), 0:02:39)
003025:0000 Title #35 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #36 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #37 was added (1 cell(s), 0:02:33)
003025:0000 Title #38 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #39 has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #40 was added (1 cell(s), 0:02:34)
003025:0000 Title #41 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #42 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #43 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #44 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #45 was added (3 cell(s), 0:04:06)
003025:0000 Title #46 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #47 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #48 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #49 was added (3 cell(s), 0:04:06)
003025:0000 Title #50 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #51 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #52 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #53 was added (1 cell(s), 0:02:12)
003025:0000 Title #54 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #55 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003018:0000 Title 7 in VTS 1 is a Multi-PGC title
003016:0000 Title #56 was skipped
003028:0000 Title #57 was added (1 cell(s), 0:02:58)
003025:0000 Title #58 has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #59 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #60 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #61 was added (2 cell(s), 0:02:39)
003028:0000 Title #62 was added (2 cell(s), 0:02:39)
003025:0000 Title #63 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #64 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #65 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #66 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #67 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #68 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #69 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #70 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #71 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #72 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #73 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #74 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #75 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #76 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #77 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #78 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #79 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #80 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #81 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #82 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #83 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #84 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #85 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #86 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #87 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #88 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #89 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003027:0000 Title 3 in VTS 4 is equal to title 1 and was skipped
003027:0000 Title 2 in VTS 5 is equal to title 1 and was skipped
003027:0000 Title 3 in VTS 5 is equal to title 1 and was skipped
003027:0000 Title 2 in VTS 12 is equal to title 1 and was skipped
003027:0000 Title 3 in VTS 12 is equal to title 1 and was skipped
003027:0000 Title 4 in VTS 12 is equal to title 1 and was skipped
003027:0000 Title 5 in VTS 12 is equal to title 1 and was skipped
003027:0000 Title 6 in VTS 12 is equal to title 1 and was skipped
003027:0000 Title 6 in VTS 1 is equal to title 9 and was skipped
003027:0000 Title 13 in VTS 1 is equal to title 12 and was skipped
003027:0000 Title 9 in VTS 2 is equal to title 6 and was skipped
001003:0020 DEBUG: Code 963 at Rf$aby`s^xes'>n!y.Rk<:121263337
001003:0020 DEBUG: Code 387 at Rf$aby`s^xes'>n!y.Rk<:121263337
001003:0020 DEBUG: Code 483 at Rf$aby`s^xes'>n!y.Rk<:121263337
001003:0020 DEBUG: Code 99 at Rf$aby`s^xes'>n!y.Rk<:121263337
001003:0020 DEBUG: Code 3 at Rf$aby`s^xes'>n!y.Rk<:121263337
001003:0020 DEBUG: Code 1 at |PtOB2PweKz7MQv!Wq:29403406
001003:0020 DEBUG: Code 2 at |PtOB2PweKz7MQv!Wq:29403406
001003:0020 DEBUG: Code 3 at |PtOB2PweKz7MQv!Wq:29403406
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory M:/Brandon's Movies
001003:0020 DEBUG: Code 2 at j_C7lEO50l;+ywKE:213135251
001003:0020 DEBUG: Code 100864262 at jJg}A8-nthu~"-#)ER:121263429
001003:0020 DEBUG: Code 100864262 at jJg}A8-nthu~"-#)ER:29393654
002003:0000 Error 'Scsi error - MEDIUM ERROR:CIRC UNRECOVERED ERROR' occured while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '3203266560'
001003:0020 DEBUG: Code 1564095 at Mwax,4q.yt`}QfhJV=#:213132836
001003:0020 DEBUG: Code 0 at T6yIc}dD+R0G\''zZ'W:29396276
005003:0000 Failed to save title 0 to file M:/Brandon's Movies/title00.mkv
005004:0000 0 titles saved, 1 failed
setarip_old
@Matt_in_Michigan
Hi!
This is likely indicating a dirty or physically damaged disc.
iPond317
Post by iPond317 »
I am having issues with a few Blu-Ray discs recently. Most recent one to give me trouble is Snatch. I am using a Pioneer BDC-202 in an external USB enclosure connected with SATA.
Debug log started at Sat Mar 20 20:16:55 2010 , written by MakeMKV v1.5.1 beta darwin(x86-release)
001005:0000 MakeMKV v1.5.1 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/ianpond/MakeMKV_log.txt
005050:0000 Evaluation version, 19 day(s) out of 30 remaining
DISCID=EACC858DD9FF544FFB0CCBE8DD01BF06A7E1B51B
003025:0000 Title #00002.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00003.mpls was added as title #0
003307:0000 File 00011.mpls was added as title #1
003307:0000 File 00012.mpls was added as title #2
003307:0000 File 00013.mpls was added as title #3
003025:0000 Title #00999.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00043.mpls is equal to title 00012.mpls and was skipped
003309:0000 Title 00044.mpls is equal to title 00013.mpls and was skipped
003307:0000 File 00979.mpls was added as title #4
003025:0000 Title #00977.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00980.mpls was added as title #5
003307:0000 File 00981.mpls was added as title #6
003307:0000 File 00982.mpls was added as title #7
003307:0000 File 00900.mpls was added as title #8
003309:0000 Title 00001.mpls is equal to title 00011.mpls addednd was skipped
003025:0000 Title #00995.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00996.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00997.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00998.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00994.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00230.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00260.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00263.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00267.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00268.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00269.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00270.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00320.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00321.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00322.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00323.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00324.m2ts was added as title #9
003025:0000 Title #00325.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00326.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00327.m2ts was added as title #10
003025:0000 Title #00328.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00329.m2ts was added as title #11
003307:0000 File 00330.m2ts was added as title #12
003307:0000 File 00332.m2ts was added as title #13
003307:0000 File 00339.m2ts was added as title #14
003025:0000 Title #00340.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00341.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00343.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00344.m2ts was added as title #15
003025:0000 Title #00345.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00346.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00347.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00348.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00400.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00401.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00271.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00999.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00970.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00971.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00972.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00973.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00994.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/ianpond/Desktop
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
001003:0020 DEBUG: Code 2 at .R=exB5Bsp5:YFgn:213135251
001003:0020 DEBUG: Code 4 at .R=exB5Bsp5:YFgn:213135251
001003:0020 DEBUG: Code 268435459 at MUu;[,G`Fw0FvjjJ=b{9qtoD^KD:213135182
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occured while reading '/BDMV/STREAM/00262.m2ts' at offset '798289920'
001003:0020 DEBUG: Code 2281701379 at @Wa&iO:,1X1 Zd-P4s:213132445
001003:0020 DEBUG: Code 2281701379 at @Wa&iO:,1X1 Zd-P4s:29393654
001003:0020 DEBUG: Code 0 at -Z^Zsj&}/VAt%-/-4Auj:213130628
001003:0020 DEBUG: Code 0 at *lN:(-P"8gO^ 7(eQbjT:213129823
001003:0020 DEBUG: Code 0 at -Z^Zsj&}/VAt%-/-4Auj:213130513
001003:0020 DEBUG: Code 389790 at -Z^Zsj&}/VAt%-/-4Auj:213129639
001003:0020 DEBUG: Code 0 at HHvO@zyl{ZKRkZCy*bYjJ:121264993
Matt_in_Michigan wrote:Tinker Bell DVD is not reading after converting. Please help. Log is below.
This error can be caused either by physically damaged disc or by a new copy protection. What region is this disc and what is the disc condition?
iPond317 wrote:I am having issues with a few Blu-Ray discs recently. Most recent one to give me trouble is Snatch. I am using a Pioneer BDC-202 in an external USB enclosure connected with SATA.
From error log it lokks like a bad usb cable (seriously). In any case it is highly recommended to check "disable direct IO" in preferences if you are running leopard or newer.
