BDAV disc from recorder: "file system is not clean"
greenlight
#1 Post by greenlight » Fri Apr 17, 2015 5:58 am
After seeing the latest version of MakeMKV fully supported BDAV discs I got excited and gave it a go. It saw the disc but upon opening it failed with the error "LIBMKV_TRACE: UDF mount: file system is not clean".
The disc used was a BD-RE DL disc created using a set top box DVR/BD recorder, burned with TV shows off the air. The recorder doesn't support finalising RE discs. The disc mounts fine in OS X and can be browsed with no problems.
I was able to successfully rip the same disc with DVDFab 9 (with the same equipment).
Debug log started at Thu Apr 16 04:27:12 2015 , written by MakeMKV v1.9.2 darwin(x86-release)
001005:0000 MakeMKV v1.9.2 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/greenlight/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE BUFFALO Optical Drive 1.00d" opened in OS access mode.
001002:0020 LIBMKV_TRACE: UDF mount: file system is not clean;
Application exited at Thu Apr 16 04:32:35 2015
