Does this mean my BD is faulty
blong3
Post by blong3 »
MakeMKV v1.8.9 darwin(x86-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.00d" opened in OS access mode.
The new version 1.9.2 is available for download at /download
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '61440'
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Title #00013.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '49152'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '61440'
Title #00800.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00359.m2ts' at offset '61440'
Title #00364.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/50358.m2ts' at offset '61440'
Title #00353.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00303.m2ts' at offset '55296'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00303.m2ts' at offset '61440'
Title #00402.mpls was skipped
Title #00405.mpls has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '61440'
Title #00407.mpls was skipped
Title #00401.mpls has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00406.mpls has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00403.mpls has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '12288'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '18432'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '24576'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '30720'
Title #00400.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00307.m2ts' at offset '61440'
Title #00404.mpls was skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00302.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00303.m2ts' at offset '49152'
Title #00303.m2ts was skipped
Title #00304.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00305.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00306.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00307.m2ts' at offset '55296'
Title #00307.m2ts was skipped
Title #00308.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00309.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00310.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00311.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00312.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '30720'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '55296'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00313.m2ts' at offset '67584'
Title #00313.m2ts was skipped
Title #00314.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00315.m2ts' at offset '92160'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00315.m2ts' at offset '98304'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00315.m2ts' at offset '116736'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00315.m2ts' at offset '122880'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00315.m2ts' at offset '129024'
Title #00315.m2ts was skipped
Title #00350.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00358.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00359.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00360.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00361.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00363.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '24576'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '43008'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '55296'
Title #00800.m2ts was skipped
Title #50357.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/50358.m2ts' at offset '49152'
Error 'Scsi error - HARDWARE ERROR:080A' occurred while reading '/BDMV/STREAM/50358.m2ts' at offset '55296'
Title #50358.m2ts was skipped
Re: Does this mean my BD is faulty
With those errors, it is a strong possibility that the drive is physically broken - OS X seems to think so.
