[Bug] MakeMKV can't open MKV File
Dazkine
Post by Dazkine » Wed Apr 08, 2015 2:10 pm
Hi there,
I ve got a MKV File that MakeMKV will not open.
Log:
Debug log started at Wed Apr 08 14:02:12 2015 , written by MakeMKV v1.9.2 win(x64-release)
001005:0000 MakeMKV v1.9.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Marc/MakeMKV_log.txt
005042:0000 The program can't find any usable optical drives.
001003:0020 DEBUG: Code 8 at %O@5\J?/4!NbVzwR(ps:213130812
001003:0020 DEBUG: Code 0 at %,K-RpRlAgSE8g>pQD?C+:29398967
001003:0020 DEBUG: Code 0 at Ghf?:gJ%6Qt*>%UgMI:121262049
001003:0020 DEBUG: Code 0 at Ghf?:gJ%6Qt*>%UgMI:121262256
005043:0000 Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
001003:0020 DEBUG: Code 0 at 4)WIw+Ol*+MC+4 p:213131479
001003:0020 DEBUG: Code 0 at 0amohwnTd7wL\.5:213139046
001003:0020 DEBUG: Code 0 at G<#u!Q/VJu[unB.}C:121262578
Application exited at Wed Apr 08 14:03:00 2015
General
Format : Matroska
Format version : Version 4 / Version 2
File size : 30.5 GiB
Duration : 2h 11mn
Overall bit rate : 33.3 Mbps
Encoded date : UTC 2015-04-08 12:44:00
Writing application : mkvmerge v7.8.0 ('River Man') 64bit built on Mar 27 2015 16:31:37
Writing library : libebml v1.3.1 + libmatroska v1.4.2
DURATION : 02:06:13.500000000
NUMBER_OF_FRAMES : 1940
NUMBER_OF_BYTES : 36514937
_STATISTICS_WRITING_APP : mkvmerge v7.8.0 ('River Man') 64bit built on Mar 27 2015 16:31:37
_STATISTICS_WRITING_DATE_UTC : 2015-04-08 12:44:00
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 2h 11mn
Bit rate : 23.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.470
Stream size : 21.5 GiB (70%)
Language : German
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : HRA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 11mn
Bit rate mode : Constant
Bit rate : 4 608 Kbps / 1 509 Kbps
Channel(s) : 7 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 4.23 GiB (14%)
Title : Surround 6.1
Language : German
Default : Yes
Forced : No
Audio #2
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 11mn
Bit depth : 24 bits
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : German
Default : No
Forced : No
Text #2
Format : PGS
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:03:14.042 : en:Chapter 2
00:04:51.208 : en:Chapter 3
00:10:46.167 : en:Chapter 4
00:14:08.833 : en:Chapter 5
00:22:58.750 : en:Chapter 6
00:29:01.792 : en:Chapter 7
00:32:23.875 : en:Chapter 8
00:38:38.250 : en:Chapter 9
00:43:45.833 : en:Chapter 10
00:47:33.125 : en:Chapter 11
00:54:43.500 : en:Chapter 12
00:59:51.125 : en:Chapter 13
01:02:40.292 : en:Chapter 14
01:06:43.833 : en:Chapter 15
01:10:16.458 : en:Chapter 16
01:20:51.625 : en:Chapter 17
01:27:39.125 : en:Chapter 18
01:32:32.333 : en:Chapter 19
01:39:02.625 : en:Chapter 20
01:45:09.875 : en:Chapter 21
01:50:18.542 : en:Chapter 22
01:55:22.875 : en:Chapter 23
02:02:02.083 : en:Chapter 24
02:07:06.958 : en:Chapter 25
Re: [Bug] MakeMKV can't open MKV File
Post by Woodstock » Wed Apr 08, 2015 5:23 pm
First question is, why would you need MakeMKV to open it? If it's already in MKV form, it doesn't need conversion to MKV...
Dazkine
Post by Dazkine » Fri Apr 10, 2015 3:01 pm
Why not ? Change Stream Order or chapternaming
Post by Woodstock » Fri Apr 10, 2015 4:18 pm
Then MakeMKV isn't the tool to use. MKVtoolnix is closer to what you're asking for.
Dazkine
Post by Dazkine » Fri Apr 10, 2015 6:02 pm
loool. There is no bug, just use another tool. thx:D
Are there any plans for showing a message like "don't use makemkv, use mkvtoolnix!" when you r trying to open mkvs with MakeMKV?
I see its my fault posting a bug instead of just using another tool
:D
Post by Woodstock » Sat Apr 11, 2015 3:22 am
Have no clue what Mike's future view for MakeMKV are... Sorry! :)
Chetwood
Post by Chetwood » Sat Apr 11, 2015 4:34 am
Dazkine wrote:I see its my fault posting a bug instead of just using another tool
Nope, it's your fault to use the wrong tool for the job. How do you plan to change stream order once you open it in MakeMKV?
Dazkine
Post by Dazkine » Sat Apr 11, 2015 4:04 pm
you don't get it. The question is not about which tool to use. It about a Bug in MakeMKV.
order weight.
The thing i was just saying i want to change stream order but thats not right. It isnt important what i want to do its just MakeMKV cant open that MKV File.
So can we talk about that topic now and not about anything else?
There is no need to answer questions nobody has ever asked.
Please read at first and post then.
I want to talk about that Bug and not about using other tools.
I also don't thing that the file ist corrupt or something like that. Because i could open it before it was processed by Mkttoolnix.
Chetwood
Post by Chetwood » Sun Apr 12, 2015 4:42 am
So it's definitely MakeMKV's fault but not MKVToolnix's? You know that how?
Post by mike admin » Tue Apr 14, 2015 2:22 pm
According to the log, the VC-1 stream is broken (at least from MakeMKV's point of view). Please open the file in mkvmerge, remove all tracks except video and cut about 10 seconds from the start. Then send this 10-second file to support@makemkv.com.
Dazkine
Post by Dazkine » Wed Apr 15, 2015 3:38 pm
ok,done
Dazkine
Post by Dazkine » Sun May 03, 2015 9:25 pm
I also tested 2 other files. The problem always occurs after doing a remux with mkvmerge 7.8.0 and VC1 Videostreams.
Bluray => MakeMKV 1.8.4 => MKV => mkvmerge 7.8.0 => MKV => MakeMKV 1.9.2 fails to open.
Dazkine
Post by Dazkine » Sat May 16, 2015 1:38 pm
Feedback?
