Predestination
jonro
Predestination
Post by jonro » Wed Apr 15, 2015 2:07 am
MakeMKV v1.9.2 darwin(x86-release) started
Optical drive "BD-ROM hp DVDWBD TS-LB23L 0600d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading 'BD-ROM hp DVDWBD TS-LB23L 0600' at offset '24978323456'
Title #00099.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '0'
Title #00102.mpls was skipped
File 00001.mpls was added as title #0
Title #00096.mpls(1) has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '0'
Title #00102.m2ts was skipped
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00016.m2ts was added as title #1
File 00017.m2ts was added as title #2
File 00018.m2ts was added as title #3
File 00019.m2ts was added as title #4
File 00020.m2ts was added as title #5
File 00021.m2ts was added as title #6
Saving 1 titles into directory /Users/jonro/Movies/Predestination
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '24978323456'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '21225136128'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '21225142272'
Failed to save title 0 to file /Users/jonro/Movies/Predestination/Predestination_t00.mkv
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '21186213888'
Re: Predestination
Post by Woodstock » Wed Apr 15, 2015 2:25 am
Your drive doesn't like the disk - it can't read parts of it.
Have you cleaned it? Finger prints cause problems like this. It can also be a badly pressed disk...
jonro
Re: Predestination
Post by jonro » Wed Apr 15, 2015 9:11 pm
It's a brand new disc. Guess it's a bad pressing.
