TrueHD issues
TrueHD issues
I am ripping Blurays to MKV. I check the button for 7.1 TrueHD in MakeMKV. When I try to play back the file in Plex, it does not play with TrueHD. I went back and ripped the disc using DVDFAB set to MKV with Pass Through, and the file then played fine. I have looked through the forum here, but did not find any information to help me. Is the a profile setting I need to do to get the 7.1 TrueHD passthrough to work correctly?
Re: TrueHD issues
The file should contain the audio track as it is on the disk, UNLESS the profile you are ripping with specifies translating it it to FAAC.
Re: TrueHD issues
Is that an actual audio format?Woodstock wrote:The file should contain the audio track as it is on the disk, UNLESS the profile you are ripping with specifies translating it it to FAAC.
Re: TrueHD issues
Let me try to clarify. I use MakeMKV and choose to have it copy all english audio streams. If the movie contains DTS-HD MA, it works great when I play through Plex and Total Media Theater. When the movies has TrueHD, all audio except the TrueHD work. I found that if I rip the movie in DVDFAB as MKV with Passthrough, the file works great in Plex and TMT. Is there a profile setting I need to change in MakeMKV to allow this to work?
Re: TrueHD issues
Hey, it was relatively early in the morning, and I was getting ready to leave to teach a motorcycle class...Romansh wrote:Is that an actual audio format?
