TrueHD issues
dostale
TrueHD issues
#1 Post by dostale » Sun Apr 12, 2015 3:59 am
I am ripping Blurays to MKV. I check the button for 7.1 TrueHD in MakeMKV. When I try to play back the file in Plex, it does not play with TrueHD. I went back and ripped the disc using DVDFAB set to MKV with Pass Through, and the file then played fine. I have looked through the forum here, but did not find any information to help me. Is the a profile setting I need to do to get the 7.1 TrueHD passthrough to work correctly?
Re: TrueHD issues
#2 Post by Woodstock » Sun Apr 12, 2015 1:32 pm
The file should contain the audio track as it is on the disk, UNLESS the profile you are ripping with specifies translating it it to FAAC.
Romansh
Re: TrueHD issues
#3 Post by Romansh » Sun Apr 12, 2015 11:00 pm
Woodstock wrote:The file should contain the audio track as it is on the disk, UNLESS the profile you are ripping with specifies translating it it to FAAC.
Is that an actual audio format? ;) :P
dostale
Re: TrueHD issues
#4 Post by dostale » Mon Apr 13, 2015 1:06 am
Let me try to clarify. I use MakeMKV and choose to have it copy all english audio streams. If the movie contains DTS-HD MA, it works great when I play through Plex and Total Media Theater. When the movies has TrueHD, all audio except the TrueHD work. I found that if I rip the movie in DVDFAB as MKV with Passthrough, the file works great in Plex and TMT. Is there a profile setting I need to change in MakeMKV to allow this to work?
Re: TrueHD issues
#5 Post by Woodstock » Mon Apr 13, 2015 4:34 am
Romansh wrote:Is that an actual audio format? ;) :P
Hey, it was relatively early in the morning, and I was getting ready to leave to teach a motorcycle class... :P
