lawless
flanntastic
lawless
#1 Post by flanntastic » Sat Dec 15, 2012 4:32 am
MakeMKV v1.7.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\HTPC/MakeMKV_log.txt
DEBUG: Code 100864144 at 3e@(qC1wCc2L'5/DbA:213132100
DEBUG: Code 100864144 at 3e@(qC1wCc2L'5/DbA:29393930
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading 'BD-ROM HL-DT-ST DVDRWBD GBC-H20N C102' at offset '21949839360'
The new version 1.7.9 is available for download at http://www.makemkv.com/download
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '65445888'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '95956992'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '38725632'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '46559232'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '34719744'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '35119104'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '58779648'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '22996992'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '46614528'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '44857344'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '6144'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '12288'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '18432'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '24576'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '30720'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '36864'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '43008'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '49152'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '55296'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '14241165312'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '14969063424'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '16316000256'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '24430215168'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '30315116544'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '15192889344'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '11871762432'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '30148147200'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '29624254464'
Title #00020.mpls has length of 23 seconds which is less than minimum title length of 300 seconds and was therefore skipped
DEBUG: Code 3221225628 at 3e@(qC1wCc2L'5/DbA:213132100
DEBUG: Code 3221225628 at 3e@(qC1wCc2L'5/DbA:29393930
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '21949839360'
File 00037.mpls was added as title #0
Title #00021.mpls has length of 206 seconds which is less than minimum title length of 300 seconds and was therefore skipped
DEBUG: Code 0 at 0]kT_\JbhO$&o:EXJ:29397035
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'
DEBUG: Code 0 at !wYS=a?5nW?)A>]Tt/:29393631
DEBUG: Code 0 at <%HMmfLQ=4[0z>Qv:213131088
DEBUG: Code 0 at v!QA;^5vv+;q]\):121268397
DEBUG: Code 0 at ^ES:6?mKZ|!<r&e>:29405844
Title #00004.mpls was skipped
Title #00003.mpls has length of 89 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00002.mpls was added as title #1
Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00017.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00016.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00015.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00013.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00012.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00011.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00010.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00009.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00008.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00007.m2ts has length of 99 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00006.m2ts was added as title #2
File 00005.m2ts was added as title #3
Title #00039.m2ts has length of 19 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00038.m2ts has length of 136 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00036.m2ts has length of 156 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00037.m2ts has length of 70 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00004.m2ts was skipped
Title #00035.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00019.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00034.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00033.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00032.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00030.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00029.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00028.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00027.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00003.m2ts has length of 44 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00000.m2ts has length of 4 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00001.m2ts has length of 9 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00020.m2ts has length of 19 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Saving 1 titles into directory I:/Video/Lawless
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '10435166208'
DEBUG: Code 0 at veva!ugM)j5-6[:G9xd#:121262739
DEBUG: Code 0 at 4|_!tcd6=dyR*e>~Y6:2:121261681
DEBUG: Code 0 at veva!ugM)j5-6[:G9xd#:213130743
DEBUG: Code 5095296 at veva!ugM)j5-6[:G9xd#:29393332
DEBUG: Code 0 at meYU{PO'Bt}6Lre7169"(:29397955
Failed to save title 1 to file I:/Video/Lawless/Lawless_t01.mkv
0 titles saved, 1 failed
setarip_old
Re: lawless
#2 Post by setarip_old » Sat Dec 15, 2012 6:24 pm
Hi!
I had no such difficulty with MakeMKV and "Lawless".
All the "Medium Errors while reading" would indicate a physically damaged or dirty disc.
Try cleaning the disc - if still NG return to place of purchase in exchange for a new disc...
Batiatus
Re: lawless
#3 Post by Batiatus » Sat Apr 11, 2015 1:43 am
I've had trouble ripping 3 different copies of this film. Must be some flaw in the master pressing causing it. Can't rip the MKV or rip the entire ISO. Frustrating.
